Originally Posted by
wizard
I may not be much help here as I’ve not done much Mac3 configuration but have a few suggestions:
1. If you want lathe like functionality run a CNC controller in lathe mode if it has one.
2. There should be config files that setup the CNC controller to associate an output with an axis. At least I hope there would be such a file.
3. From my perspective running a mill / router with a rotary axis is not the same thing as having a CNC lathe. It is probably best to try to determine which approach is best. It is kinda hard to tell from your post what your goals are. It seems like you want both types of functionality.
4. Interestingly in the past I’ve come across web sites by guys using machines to do Pool Cues that may have practiced knowledge that might help you.
