Need Help! Change CNC Controlbox
Results 1 to 11 of 11
Thread: Change CNC Controlbox
    Dec 2014
    Default Change CNC Controlbox
    I have a CNC that is self contained so doesn't need to be connected to a computer, I just add the file to cut onto a mini SD Card and put it into the Controlbox. I'm now wanting to connect directly to a computer so what recommendations does everyone have for the Power supply and controlbox replacement? Its 600x300 and 1500w Spindle
    Attached Thumbnails Attached Thumbnails Change CNC Controlbox-image-jpg
    Member ericks's Avatar
    Sep 2019
    Default Re: Change CNC Controlbox
    Quote Originally Posted by KenR60 View Post
    Do you plan on upgrading your stepper drives too?
    Dec 2014
    Quote Originally Posted by ericks View Post
    I wasn't planning too, the CNC has only done around 30 hours since new.
    Sep 2019
    So you happy with the overall performance of the controls?
    Dec 2014
    Was a lot of setting up and mucking around originally when I bought it, I haven't used it for around 2 years so I just want an easier system so I can control it directly
    Sep 2019
    Okay, are you using mach3?
  7. #7
    Dec 2014
    Happy to use anything, if I remember I couldn’t use mach3 because it wasn’t connected to a computer
  8. #8
    Sep 2019
    Of course yes...
  9. #9
    Sep 2019
    I use uc300eth on my machine with an Aussie made breakout board. Both work very well for me. The UC300 require a 5V psu and the bob a 12V. But there are many other options as people will most likely tell you.
  10. #10
    Sep 2019
    Can you take a pic of inside the box, maybe you have enough space inside to do the mod
  11. #11
    May 2005
    I’m trying to determine your motivation here. There are so many options it is hard to say what is best. The first thing that comes to mind is this does the current controller support drip feed or other PC to controller communications. Is it does that would be the cheapest way to improve file handling.
