Need Help! Limit Switches configuration.
Results 1 to 1 of 1
Thread: Limit Switches configuration.
    Feb 2005
    United Kingdom
    Default Limit Switches configuration.
    Almost finished the rebuild of my CNC Router,
    Im using MAch4 with and ESS Smooth Stepper
    All 3 Axis are running fine but I need help on the configuration and placement of my limit & Home switches.
    I'm using a switch at each end of the x Axis and the Y Axis and one switch at the top of travel on my Z Axis.
    I may have assigned these wrongly so please advise If I need to alter them.
    I'm getting errors such as 'Cant jog towards x-' etc
    So I need to configure them in the ESS Plugin and Mach 4 setup.
    Any help would be appreciated.
    many thanks
    George
    Attachments Pending Approval Attachments Pending Approval
