Try 13,000 rpm, and they should last at least 50% longer.
Try a coated bit like an Amana Spekta, for even longer life.
I like using downcut bits, I normally cut hardwoods, and onion skin the parts. A downcut leaves a nice sharp edge on my parts.
But I am finding that they don't seem to last long. In hardwoods I normally use a 1/4" bit, .25" DOC, 18000rpm (Spindle max speed) and 150 ipm. Cut part .01 oversize and follow with a full depth pass to clean up. Dust collection running.
With a new bit I get a real nice finished surface I'm not sure how much I cut but it seems like my downcuts don't last as long as my straight cuts.
So what bits have you used that have a good tool life?
- Tool Life Management: Tool Life Expiration Signal always on even aft switching tools?
- Newbie- Best place to buy good value (i.e. lower price good quality) CNC router bits on web
- Need Help!- Heidenhain M101 - Auto Tool Change If Tool Life Expires
- 3/4 Baltic Birch, 1/4 Downcut. Feeds? Speed? Plunge?
- Renishaw tool offset / break probe and tool life management
UCCNC 2017 Screenset
Raise your feed rate or lower RPMs. Assuming a 2-flute cutter, your chip load is way too low and your bit is losing its hardness due to heat. The issue is also compounded due to the downshear trapping chips in the bottom of the cut.
This calculator shows you should be running at 8,000 RPM max at 150 IPM. https://www.guhdo.com/chipload-calculator I see that this is below the range of RPM on your spindle, what is your max feed rate?
Make chips not dust! A bigger chip will carry heat away from the cut.
I got a new bit I purchased a freud from woodcraft. I tried all of the the suggestions, and what seemed to work well was the following settings:
15000 rpm, 250 ipm, 3/8" doc, with a full depth .01" clean up pass in 3/4" hard maple. Dust collector was running and the channels were about 1/2 to 1/3 packed at the bottom when done. I cut around 30 parts, the cycle was about 40 min. When it was done I touched the bit, it was very warm, but not so hot that I couldn't keep my fingers on it. I figured this was pretty good and should give decent tool life. All of the chips were tiny squares, not powder like I was getting.
And on the plus side since I'm doing 3/8" doc instead of the 1/4" that I was doing, my cycle time improved quite a bit. I started an excel spread sheet and will keep track of the number of parts with the settings, and in a few months I will see how I'm doing. I want to try a couple of other bits as well.
I ran Yonico and Onsrud 57-xxx serie with good success but Onsrud finish is a tad better and last 25%-50% longer. Yonico is almost half the price of Onsrud depending of vendor.
Mostly in maple, birch, walnut and some birch plywood
Edit: At work we have FS Tools cutters that are incredible but they cost an arm and a leg.
