New Machine Build Second build - Steel heavy gantry machine for aluminium
Results 1 to 19 of 19
Thread: Second build - Steel heavy gantry machine for aluminium
    Apr 2008
    Slovenia
    Default Second build - Steel heavy gantry machine for aluminium
    After completing my 1st build and using machine for more than 3 years i have come to point where i need upgrade.
    My first machine was intended mainly for wood and some light aluminium cutting and now machine is only working aluminium and some rare light wood cutting
    1st build was all aluminium and now i'm having some troubles with vibrations and rigidity of machine. But still i'm cutting parts out of aluminium in tolerances of 0.05mm which is good for machine not intended for this type of work.
    1st machine photo and some parts
    Second build - Steel heavy gantry machine for aluminium-img_4837-jpgSecond build - Steel heavy gantry machine for aluminium-img_0847-jpg
    Second machine will be all steel maybe some parts from EG or solid granite.
    I'm liking design from Datron MxCube so this will be some kind of mock-up from that and my ideas. (also i have friend who work in granite machining center, so that can help )
    Plan is to build machine capable of milling aluminium parts without any problems with good tolerances 0.01mm.
    So i'm aiming for working area of 1000x1000x300mm
    Welded structure filled with sand or EG. (cca 500kg)
    Gantry - steel EG combination cca 150-200kg
    profile rails 25mm on all axes
    20mm-25mm ballscrews on all axes probably with 10mm pitch.
    Double ballscrew on Y axis.
    Servo motors, looking on DMM 400W set, but i dont know if this will be enough for gantry of this weight.
    Probably teknomotor spindle, still deciding if i should go ATC or not.
    So i have started designing cad and i have come to my first dilemma.
    Gantry beam is 120x220mm steel tube wall thicknes 12.5mm (80kg)
    I'm deciding should i build gantry sides like left or right side.
    Second build - Steel heavy gantry machine for aluminium-gantry-jpg
    left - solid block of epoxy-granite with embedded steel plate for bearing and gantry to bolt on .
    right - hollow welded steel side out of 10mm steel sheet
    weigh of both is pretty much the same (20kg) but i think that vibration dampening will be better on left side.
    This will be project for next year so now i'm in cad phase. So any input in design will be appreciated.
    What so you guys think ?
    Luka
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Second build - Steel heavy gantry machine for aluminium
    Hi Luka - Sounds like its time for a pull down and rebuild if your getting vibs. Bearings need checking after some time. If you can go granite I'd work on that. But remember vibs do not come from the structure they are driven from the motors or the tool. So isolate motors from the structure and the spindle holder....Peter
    Apr 2008
    Slovenia
    Yes i think that too.
    I'm suspecting my spindle bearing and overall structure of z axis.
    Yes i have decided to go with granite or EG, this will also be easier for me to build as i'm not good with welding and all post welding operations will cost me in the end more than casting EG.
    As i'm in Europe i have pretty easy access to Silimix 282 - i'll probably use that. (I need to calculate if it's worth mixing aggregate by myself)
    But now after reading for some time about C-frame, Bridge and Gantry designs i'm really not sure what i want
    If i'm rebuilding cnc I would like to make machine that will be versatile and good for all possible work that i will be doing.
    That including milling steel.
    At first my requirement was worktable of 1000x1000mm (that would be possible with Gantry design) but i think that will not be possible if i want to mill steel as i'm reading that Gantrys are not good for steel.
    Everyone is saying that if i want to mill steel i need fixed bridge or C style VMC.
    For spindle i'm thinking i should go with double spindles, one for steels and other for all other softer materials.
    one BT30 + servo and second High speed 2.2kw 24000 (i already have this one)
    Luka
    Jul 2018
    dum dum
    Hi Lukahr - Gantries are used for steel just they need to be very very stiff probably 200x200x12 at least in steel. Look at a moving column design... I'm designing an epoxy high modulus fibre moving gantry mill at the moment...Peter
    I expect your machine to have a moving control cabinet as well....
    https://www.industrialmachinery.net....moving-column/
    "Epoxy-Granite machine bases (was Polymer concrete frame?)" look at the last pages of this thread for info on epoxy granite
    all my reading and calculations say that good sand and epoxy is as good as the graded approach. Keep it simple.
    shrink this one down...
    Attached Thumbnails Attached Thumbnails Second build - Steel heavy gantry machine for aluminium-tetrium-jpg
    Apr 2008
    Slovenia
    I'll check what aggregates are needed for good EG mix and if i can source them localy.
    Drying sand is really no problem for me as i have at home industrial wood drying kiln machine.
    I'm not so fond of this moving column design. I think it is really hard to get good stability of moving column looking like skyscraper
    If bearing blocks would be more wide apart on the bottom - maybe.
    Or design like this DMG machine this one looks solid.
    Jul 2018
    dum dum
    Hi Lukahr - Yes extremely solid. I do intend to space the column bearings further apart. The DMC machine still has a saddle and that's something I wanted to get rid of. But you have me thinking.... a static table has advantages as well.... Peter
    Attached Thumbnails Attached Thumbnails Second build - Steel heavy gantry machine for aluminium-dmc-jpg
  7. #7
    Apr 2008
    Slovenia
    Yea i'm fan of static table and CNC that i own now has static table and i'm really liking it.
    Regarding my design now it has totally shifted over
    Here is a design sketch that i'm working on now.
    I decided that i will go with 1x1m work-space and welded base filled EG or polymerconcrete.
    Second build - Steel heavy gantry machine for aluminium-img_5099-jpgSecond build - Steel heavy gantry machine for aluminium-img_5100-jpg
    This will be heavy machine.
    I'm planing to mill steel with it so it need to be rigid.
    Main vertical columns are 150x150mm, all others 150x100mm 6mm thick.
    Now i'm deciding on choosing linear rails and blocks.
    I'm deciding between
    BST motion - HIWIN ball bearing size 35 or 30mm
    TBI motion - HIWIN roller bearnig size 25 or 30mm
    Price is actually very close so i dont really know what to pick, bigger ball block or smaller roller blocks .
    Also BST motion has good reputation, for TBI motion i'm not sure .
    I'm going for at least medium pre-load if not high preload.
    Luka
  8. #8
    im using hiwin roller RGW model now i think its pretty silent compare to ball
  9. #9
    Apr 2008
    Slovenia
    Quote Originally Posted by teamloks1 View Post
    What about rigidity ? roller type should be better than ball
    Where did you buy yours ?
    Yes i have looked at same model RGW - with flange, preload ZA (medium) and H accuracy size 30mm
    https://www.aliexpress.com/item/3289...7fdd5956HKl7bw
    They have both RGW and RGH models but i like flange unit more as mounting bolts are bigger m10 comparte to m8 on HGH.
    I
  10. #10
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by lukahr View Post
    Luka
    Looks good filled with EG should work well, your weakest link will always be the Z axes so a lot of focuses on that part will give you a very well build machine
    Make sure you can machine the Rail mounting faces
    Mactec54
  11. #11
    I
    since im from malaysia i bought directly from taiwan this is the model i bought
    RGW25HA2R3000ZAH+KK 2 UNIT
    RGW25HA2R2400ZAH+KK 2 UNIT
    RGW25HA2R550ZAH+KK 2 UNIT
    im ordering custom with double seal and scrapper
    that cost me around 880 usd for 6rail and 12 block
  12. #12
    Apr 2008
    Slovenia
    Yes whole machine will be filled.
    I'm planing to make something similar to this design. I will also use pneumatic counterbalance on z axis.
    Second build - Steel heavy gantry machine for aluminium-z-axis-jpg
    Marked with red will be position of my servomotor spindle 2.2KW (30 minutes 3.7kw) 12000rpm
    Second build - Steel heavy gantry machine for aluminium-z-axisv2-jpg
    All mounting faces will be milled in company that will weld frame for me.
    After transport to my place and finding right place to put this heavy machine whole think will be filled with EG or Polymerconcrete.
    So no more moving machine after filling. (it will be to heavy anyway)
  13. #13
    Apr 2008
    Slovenia
    Ok that is really good price,
    You have blocks rated super heavy with medium preload and high precision option with addition of double seal and scrapper.
    What are the ballscrews you use ?
  14. #14
    yes anyway this is router im going to make still thinking hard about frame. i use RFBY2525 rotary ballnut from TBI
  15. #15
    Apr 2008
    Slovenia
    I'm looking for my ballscrews, and i'm loking TBI brand diameter 25mm step 5mm or 10mm.
    I see they have rolled c5 and ground c5 , what is the difference in accuracy if both are c5 should be same, or not?
  16. #16
    im not sure about it im using ground c5 double nut for my z axis this cost me 150usd with bk15 c5 angular+bf15 seat
    Attached Thumbnails Attached Thumbnails Second build - Steel heavy gantry machine for aluminium-img_20191124_122027-jpg
  17. #17
    Apr 2008
    Slovenia
    Nice little setup you have there.
    Do you maybe know what series is this ballnut ? OFI&DFI ?
  18. #18
    Jul 2018
    dum dum
    200x200x13 is 9724mm2 so its 9724*1000*2700e-9= 26.5kg/m so they want 136/26.5= 5.13USD per metre ie $7.70AUD per metre yes that's a very good price compared to my local prices in Oz for short length (about $10AUD/kg here). Wouldn't use the 100x100 too small and the 200x200 gives you good room for bearings. 13mm is good for threads. Use it for other areas as well. Good section. Cheers Peter S
    yeah error 403 seems to be gone.. Peter
  19. #19
    its OFU
