Timing Belt Opinions
Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Timing Belt Opinions
    Member Project_Hopeless's Avatar
    Feb 2019
    Sterling Heights Michigan
    Question Timing Belt Opinions
    For my DIY CNC router I'm thinking about using 2GT-3M timing belt and pulleys, 1:1 ratio for my Z axis. It will reduce the machine height compared to my direct drive concept.
    I was thinking 30 teeth, 9mm width. What size pulley would you choose, number teeth, width?
    Aug 2009
    Default Re: Timing Belt Opinions
    Is that a belt drive going to a ballscrew, or a direct mount of the Z to the belt?
    Oct 2004
    A 9mm 2GT belt is awfully small. Those are better suited to a no-load application like a 3D printer.
    May 2005
    Timing belts would be fine for a certain class of work, so the first question is what are your intentions.
    Beyond all of that timing belts for most router implementations are almost always undersized on DIY builds. I work on a lot of pick and place robots (extractors) and special function machines and the belts used there are often 50mm wide, sometimes wider. To get the positioning accuracy needed the belts are tensioned very tight. This tensioning requirement is the second big issue on home builds, you can easily bend or warp a light frame or gantry beam. The mechanical arraingement of the drives is also important as you need to minimize belt slap or oscillation.
    Belt drive isn’t impossible but it might not give you what you need.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Hopeful - 9mm is too narrow. Needs to be at least 16mm wide depending on the stiffness required. I'd use the widest pulley you can put on the motor shaft. My router has 16mm wide belts on all axis and next time I'd use 25mm. Prefer 32mm but too wide to get onto motor shafts. Usually height is not a problem. Direct drive is best so if height is actually not a problem (like it has to fit into a certain height space) I wouldn't use the belt. Cheers Peter
    Feb 2019
    Quote Originally Posted by __Britt View Post
    Yes it will drive a 1204 ball screw.
    I'm trying to get the CG lower on the machine. Direct drive will have the motor high in the air. Seems like a lot of mass up high during high speed moves.
    Pictured is the Z axis at the extreme stroke limits, left two images direct drive, right belt drive.
    Timing Belt Opinions-z-axis-concepts-01-jpg
    Timing Belt Opinions-z-axis-concepts-02-jpg
    Nothing has left the drawing board yet!
  7. #7
    Jul 2018
    dum dum
    Hi Hopeless - I personally would not worry about the height, your gantry rail spacing is very big, it will cope easily unless you are aiming at 1G plus moves? . You are using rails for the Z yet round shaft for the gantry? Rail is much stiffer? I'd only use the belt if you needed a gear ratio. If 1:1 works then go direct.. Peter
    I also think your saddle plate and Z plate need to be thicker or have webs on the sides. They will wobble quite a bit when they are thin and flat when cutting, a much bigger concern then the high mass.
  8. #8
    Jun 2010
    I use GT2 belts myself between motor and ball screw, motor and harmonic drive.
    The 6 mm ones are usually quite enough for that: they have incredible strength which few seem to understand - and many pulleys and belts can be bought from ebay for low cost. You would need to be pushing very high accelerations to justify going up from 6 mm to 9mm between motor and ballscrew. You should note however that Chinese GT2 belt profile is slightly different from Gates GT2. Not much, just simpler. The original profile (in the patent) was an attempt to block copies by being excessively complex. It didn't work
    For direct drive something a bit wider could be advised. 16 mm with correct tension should handle many routers. Going up from there is expensive and of questionable value. Note however 'correct tension'.
    Z axis web plates - yeah, a bit light.
    Cheers
    Roger
  9. #9
    Member teamloks1's Avatar
    Feb 2019
    where did you all find big belt i only found 9mm belt currently using 9mm belt with 1kw servo driving 40kg z axis
  10. #10
    Jun 2010
    6 mm GT2: used on little 3D printers, so hordes of Chinese suppliers.
    Wider than that: European or USA suppliers only. A bit more $ of course.
    Timing Belt Opinions-7331-jpg
    Z axis. 9 mm GT2 belts bought in, Gates brand. Pulleys with GT2 profile and custom taper lock: I had to make these myself.
    GT2, correctly tensioned, does not have detectable backlash. This set replaced the original 'timing belt' as that older profile does have backlash. I can measure a 0.8 um single step resolution with this with a Z axis touch probe.
    Cheers
    Roger
  11. #11
    Aug 2009
    I'm not a mechanical engineer... so this could be a totally bogus notion... but... how about putting multiple 6mm belts on it?
  12. #12
    Jun 2010
    Those GT2 elts are much stronger than you might think.
    I have seen 3 or 4 V-belts in parallel, on proper pulleys. It should, in theory, work here too. Need to handle the tracking problem.
    Cheers
    Roger
