1st Build, will this be a decent Design? - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 81 to 96 of 96
Thread: 1st Build, will this be a decent Design?
  1. #81
    Member mactec54's Avatar
    Jan 2005
    Default Re: 1st Build, will this be a decent Design?
    Quote Originally Posted by BigFellaPhil View Post
    So I've found this and from what people have said I think it will be suitable, does anyone have any thoughts before a go ahead and buy it... - https://uk.farnell.com/multicomp/vtx...P_LastViewed_1
    Here are some ready to go they have Voltage and Amperage range, PS-10N50 - 1000W 50V Power Supply - AnTek Products Corp
    Mactec54
  2. #82
    Member BigFellaPhil's Avatar
    Aug 2019
    Hi Peteng - Yeah I was originally going for the Switching Type PS, however after reading a bit more into it and advice/info on here I decided to go down the Toroidal PS route.
    Rcaffin - I kinda thought the 40V would increase slightly when it goes through the Bridge Rectifier (unless I miss understood this?) I thought the 40v would increase to 56v???
    Macec54 - Yeah that PS is what started this thread off, someone else already posted that and I was all set to buy it, then realised they wanted another £100 to deliver to the UK. So now I'm trying to source the parts to make a Toroidal PS myself but finding it difficult to get a Toroidal Transformer here in the UK that matches the specs in your link above!
  3. #83
    Jun 2010
    You are in the UK, right?
    Try https://uk.rs-online.com/web/p/toroi...rmers/1176080/
    Then wander through their range.
    I have very serious doubts about putting a cap on the output of an SMPS. With some units that can destabilise the whole thing! It may stop working. But you CAN put a double-winding E-core filter to block the spikes. I do this myself on my spindle drive, and it works just fine.
    Cheers
    Roger
  4. #84
    Jan 2005
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Yes you can use Cap on the output from SMPS, have been doing it for years, one of the Breakout Boards Dmm manufacture has 2 Caps to filter the power from 48V /60v SMPS up to 20A
    Attached Thumbnails Attached Thumbnails 1st Build, will this be a decent Design?-dmm-breakout-board-jpg   1st Build, will this be a decent Design?-4-axes-wired-kit-1-2-jpg   1st Build, will this be a decent Design?-4-axes-wired-2-2-jpg
    Mactec54
  5. #85
    Jun 2010
    Fair enough. I don't know the DMM range. My experiences have been with different brands.
    Do you know what the black cubes on the bottom chassis are? Could they be filter inductors? Or just some fancy sort of connector?
    Cheers
    Roger
  6. #86
    Jan 2005
    Cheers
    Roger
    The Black cubes I manufacture are just terminal Blocks that whole package is 4 low 60v volt 20A Ac Servo drives with built in Breakout Board a plug and play package I used to build
    Attached Thumbnails Attached Thumbnails 1st Build, will this be a decent Design?-terminal-blocks-parts-finished-7-2-jpg   1st Build, will this be a decent Design?-case-parts-connector-terminal-block-2-jpg
    Mactec54
  7. #87
    Jun 2010
    Hi Mactec
    Very nice stuff! Very nice assembly too.
    To explain a little bit (for others maybe):
    An SMPS switches the supply through to the output at a very high on/off rate. The average of the mark/space ratio is what sets the output voltage. The output of the switching stage is inductively filtered to produce a DC voltage with a saw-tooth waveform superimposed. The key point here is that the control circuitry looks at the filtered output as it rises and falls, and uses the levels it sees to control the switching. This is how every SMPS from a tiny wall-wart to a multi-kilowatt supply works. For that matter, it is also used at the grid level.
    If you put a big cap across this output directly, smoothing the ripple out, the control circuit cannot see the varying voltage the way it should, and the switching is upset - badly. However, if you put an inductance AFTER this monitored output stage and feed that into a big cap, then the control circuit will still see the varying voltage but the output will be much smoother.
    My spindle PS does not have this output filtering, and many other 'simple' SMPS packages don't either. However, it would appear that some SMPS units do have this output stage filtering (the more expensive ones!). If the filtering is good enough, then there won't be lots of RFI on the supply lines into the motor power drivers, As modern power drivers are also SMPS units, you don't want them being upset by RFI on the input lines which could confuse the control circuits.
    I was a bit too sweeping in my previous statement about not putting a cap on the output of any SMPS supply.
    The problem then is to find out whether the SMPS you are considering buying has output filtering to reduce the RFI. Very often this information is not given in the specs. You may have to ask the manufacturer - or buy the supply and measure the output voltage with a CRO.
    Cheers
    Roger
  8. #88
    Aug 2009
    CRO
    It doesn't need to be a Cathode Ray Oscilloscope... any digital scope should work for the task, also.
    Of course - no matter which type you have - watch out for grounding issues!
  9. #89
    May 2005
    The bit which puzzles me is that 2 of the trannies were <40 quid each, but the slightly higher voltage version with the same powwer rating was 122 quid. Something a shade strange there.
    The advantage of a tranny/diode/cap PS over an SMPS one is that you cannot blow up the tranny by dumping reverse charge from deceleration into it, but you can blow up the SMPS that way. A second advantage is that the RFI from the SMPS can send your driver mad: such drivers are not built to handle that sort of incoming RFI.
    YMMV.
    Cheers
    Roger
    The issue of blowing up a SMPS, from high bus voltages, is probably the best reason to avoid them. The alternative is to look for DC SMPS specifically designed for servo / stepper duty. The other advantage is that transformer based supplies are dead simple to repair which for me is a big deal.
  10. #90
    Jun 2010
    Ah well, these days 'CRO' = oscilloscope.
    I gave away my last genuine CRT-based oscilloscope some 20 years ago. Very good Tektronix one too.
    Cheers
    Roger
  11. #91
    Aug 2009
    I still have... I think it's back under the old LaserJet 5mp, in the closet... a Tektronix AN-425. It's more-or-less in mint condition; so I think it was a stockpiled-spare that one of the branches of the armed forces here was keeping... I'm afraid that I haven't pulled it out since I got my first Rigol, though...
  12. #92
    Jun 2010
    I think I started with a Tek 556 with 1A1 plug-ins, but the nuvistors died, so I graduated to a Tek 475. I gave that one to a friend when it developed a problem - he had the bits to repair it, and now I have a Tek TDS 220. I had to repair the front end BNC connectors : a known fault with the BNC connector design.
    I don't recognise the AN-425 though.
    Cheers
    Roger
  13. #93
    Aug 2019
    Thanks to everyone involved in this thread, I received my Toroidal PS this afternoon, it's been out of stock for two weeks but this is my set-up and after testing it I'm getting 69VDC final output so I'm more than happy with it. I just need to tidy it up a bit as it looks a bit messy at the moment, this layout is just for testing purposes.
    Thanks again for all your input, I got there in the end and saved over £100 so I'm happy!
    Attached Thumbnails Attached Thumbnails 1st Build, will this be a decent Design?-20191014_172032_resized-jpg   1st Build, will this be a decent Design?-20191014_172004_resized-jpg
  14. #94
    Jun 2010
    Hi Phil
    Put that diode bridge on a heatsink, PLEASE!
    At 10 A and 1.8 V across the bridge, it will be dissipating 18 W.
    Cheers
    Roger
  15. #95
    Aug 2019
    Hi RCaffin,
    I found this Heatsink in an old computer parts box I had, is it ok, do ya think?
    One thing I've noticed is the Capacitor is holding a charge for an unthinkable amount of time, when I initially tested it I had a resistor to help discharge the capacitor, and it did it in around a few hours. I've since removed the resistor, I knew the Capacitor would take longer to discharge, however, I didn't think it would take more than a day.... so far it's taken 5 days and it's only at 37V now (from an initial 69V.) so it's only dis-charging at around 6V a day!!??? I'm starting to think I should have left the resistor on but I just thought it wouldn't work as it's bridging the +/- Outputs which didn't seem logical to me..?
    Attached Thumbnails Attached Thumbnails 1st Build, will this be a decent Design?-20191030_165153-jpg
  16. #96
    Jun 2010
    That will help for sure. It would help if you could lift the heat sink 5 - 10 mm up in the air: get better air circulation.
    As for the discharge rate - that sounds really wrong to me. Those electrolytics have an internal discharge or leakage of their own.
    I would want to check the AC input lines: it sounds as though they still have volts on them. How that could happen is another matter!
    Yes, you should have a discharge resistor across the cap anyhow. A 10 k power resistor would be fine.
    I would also add a fuse on the AC input, just on general principles. It is OK to switch the AC input, but do not switch the DC output: that can damage the motor drivers.
    Eventually you may want to bolt the toroid to a metal base plate: it too will get warm and need to dissipate heat. The insulation provided is adequate for that (but check the specks anyhow).
    Cheers
    Roger
