1st Build, will this be a decent Design? - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 75 of 75
Thread: 1st Build, will this be a decent Design?
  1. #73
    May 2005
    Default Re: 1st Build, will this be a decent Design?
    The electrical ampacity ratings of wire are based on a number of things including the temperature rating of the insulation. If you are in an area where the NEC applies acceptable current ratings can be defined in the code (for specific usage). Transformers are an interesting discussion but I think I’d side with others and have to question the wisdom of 18ga wire in a secondary operating at greater than 15
    The reality is comments from a transformer designer / engineer would shed more light on the issue. The other problem here is the fact that far too many online sellers have no idea what they are selling. The 18 ga could easily be the primary.
    Quote Originally Posted by __Britt View Post
    Disclaimer: I am not an electrical engineer; nor do I play one on TV.
    Well, FWIW there is this:
    https://www.powerstream.com/Wire_Size.htm
    At 56v, 1000 watts is about 17.9... lets call it 18 amps.
    18ga wire, according to that chart, should be good up to about 16 amps in free air; but only 2.3 amps in a bundle... this leads me to thinking that the wire in question is a bit on the light side for the task at hand. On the other hand; I often see transformers wound with lighter gauge wire than what is feeding them, so... ???
  2. #74
    Aug 2009
    The Great Internet Giveth, and the Great Internet Taketh Away... (low prices, and competency, respectively, in this case).
    18 on the primary would tend to make more sense...
    I wonder if dropping a line to Antek might be enlightening... they do manufacture torroidial transformers from scratch, so... ???
  3. #75
    Jun 2010
    I do not understand where the problem is. A toroidal transfomer of 1kW capacity and 10 or 20 A output at 50+ V is an off-the-shelf item in America. Also in Europe and elsewhere. Retailers have them. What's more, several mfrs will wind a transformer (eg 1 kW) to your specs. Just Search.
    There are lots of them on eBay too, although you will have to crawl through the listings in most cases to get the actual specs.
    Cheers
    Roger
