- Bosch 1615evs bypass speed control
Can a Bosch 1615evs speed control be bypassed?
Re: Bosch 1615evs bypass speed control
I don't see why not, just connect the motor directly to the mains voltage and it will run at maximum speed.
The drawback is that the soft start circuit (if there is one) will be bypassed as well. Any particular reason you want to do that?
- You may not post replies
- You may not edit your posts
Forum Rules
