Need Help! Motor Coupling Question - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Motor Coupling Question
  1. #13
    Mar 2017
    Default Re: Motor Coupling Question
    I prefer the clamping spider type couplers myself. Often they can be had with both a setscrew and a clamp. Take note, the one you have has a bit of torsional spring to it and this will increase your backlash.
    Good couplers are not cheap. https://www.anaheimautomation.com/pr...D=1206&cID=559
  2. #14
    Member Mecanix's Avatar
    Aug 2019
    Quote Originally Posted by maxspongebob View Post
    Failed to see this until today, never used those torsional-twisties spring types anyway, seen them before though. You are actually correct... that L difference between pull/push must be huge. Why are those still being sold today?! A 'spring' for coupling (lol)
  3. #15
    Member Jim Dawson's Avatar
    Dec 2013
    These are my prefered couplings https://www.automationdirect.com/adc...ervo_couplings
    Expensive but they work well, they use a bushing that is clamped to the shaft with the set screws.
    Jim Dawson
    Sandy, Oregon, USA
