How Do You Tram Your Router - Wood Build - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: How Do You Tram Your Router - Wood Build
  1. #13
    Dec 2003
    East Anglia,England
    Default Re: How Do You Tram Your Router - Wood Build
    Quote Originally Posted by wmgeorge View Post
    Or go to say Home Depot and purchase a granite floor tile.
    I think they might be a bit puzzled by people going through the tiles with a micrometer,seeking an exactly parallel piece.
  2. #14
    Apr 2016
    Granite should work, but only if one makes sure the tile is truly flat and coplanar. Some tiles aren't flat & coplanar enough for accurate tramming. Unfortunately, probably not possible to check them in the store to any degree of precision.
    The Old Man and the C -----NC
  3. #15
    Mar 2003
    Shelby Township
    The polished black ones should be flat enough.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #16
    Sep 2005
    FYI granite is slices cut with a saw and one side polished more than the other. Its actually cut after the grinding and polishing. Very exacting process, You Tube videos if your interested.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  5. #17
    Member Project_Hopeless's Avatar
    Feb 2019
    Sterling Heights Michigan
    I just might have a piece left over from my fireplace hearth I can use. Who would have thunk it
