collets off from amazon
Results 1 to 6 of 6
Thread: collets off from amazon
    Default collets off from amazon
    Hello everyone, I am wondering from precise bits there is upgrade option to ER style collets. However I am wondering if I can just purchase the nut and spanner wrench from them for my Bosch 1617EVS, then purchase ER20 collets off from amazon?
    Mar 2003
    Shelby Township
    Default Re: collets off from amazon
    No.
    Precise Bits "ER Style" collets are not actual ER collets. ER20 collets will not fit.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Sep 2005
    I got a set off Amazon and they are just ok, but borderline "Junk". I then purchased ones that were $15 each and I can not remember the name, but the difference is Day & Night.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Apr 2016
    Quote Originally Posted by wmgeorge View Post
    Having a senior moment, Bill?
    Techniks brand.
    Gary
    Sep 2005
    Yup and another Birthday coming up very soon. The Amazon ones I struggled to get bits and out of and yes they were inch sized. The Techniks, easy in , easy out, a joy to work with.
    May 2005
    My personal opinion is that Amazon is the wrong place to be searching for collets if you don’t know the vendor and the supplier they are using. The reason here is simple, there is a lot of crap available through Amazon. Combine that with the idea that collets are pretty critical to getting good results out of your machine I’d highly suggest shopping carefully. If you do go Amazon verify that vendor supplies quality stuff first. The quality varies so widely that you can’t assume you will get your money’s worth.
    Frankly if I was on a budget I’d look towards buying a single collet at a time from a reputable supplier to industry. A decent supplier will also uplift the product and if required accept returns for defective items.
    As for Precise Bits I have no idea as I haven’t used their stuff. Generally if you want to use ER collets it is best to buy a spindle supporting those collets.
