New Machine Build Just another extrusion/Aluminium CNC
Results 1 to 17 of 17
Thread: Just another extrusion/Aluminium CNC
    Default Just another extrusion/Aluminium CNC
    Hi. I'm working on this build for about 2 years now and jsut wanted to share some pictures of the progress.
    The Framesize is 1000mm x 800mm. It is a direct driven dual drive gantry design inspired by the famous Gabriels build.
    It uses 25mm linear rails on all Axis and 1605 ballscrews on X & Z and 2005 on Y. I wanted 10mm pitch at first but ordered 5mm pitch... and for now can live with it.
    Motors are high torque Nema23 steppers. In the future I update to 400W Servos.
    Everything was done with simple tools like a drill stand and a sliding mite saw.
    This is how it will look at the end:
    Just another extrusion/Aluminium CNC-bildschirmfoto-vom-2019-05-20-19-18-a
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-bildschirmfoto-vom-2019-05-20-19-18-a   Just another extrusion/Aluminium CNC-bildschirmfoto-vom-2019-05-20-19-18-a   Just another extrusion/Aluminium CNC-bildschirmfoto-vom-2019-05-20-19-18-a
    Default Re: Just another extrusion/Aluminium CNC
    This it how it looks at the moment:
    Member machinehop5's Avatar
    Aug 2009
    now what .leaders need a dogx2
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by millhouse_ View Post
    5mm pitch Ballscrews are good for Zaxes but not X and Y you want at least 10mm Pitch for X and Y Axes
    Mactec54
    I wanted 10mm pitch but ordered 5mm. **** happens but I can live with it.
    Jan 2005
    If you do use the servos it won't be to bad for speed, but the steppers would be very slow
    Mactec54
  7. #7
    May 2005
    Or how it looks as rendered.
  8. #8
    I received the large Profiles yesterday and mounted them. Next step is aligning and squaring everything which feels like it will be much butthurt.
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-h1-jpg   Just another extrusion/Aluminium CNC-h1b-jpg
  9. #9
    Very Cool!
  10. #10
    @fretman_2 thanks. I'm very happy with it too.
    PS: Some pictures of the aligning process will follow these days.
  11. #11
    Today I started aligning some parts.
    The left Y Profile was clamped in position with 1-2-3 blocks and attached to the bottomframe.
    To flush both Y profiles I clamped them between the motormounts.
    Just another extrusion/Aluminium CNC-22-jpg
    To get a little pressure from above I improved a bit:
    Just another extrusion/Aluminium CNC-21-jpg
    With everything clamped that way I tightend the Anglebrackets of the secondary Y Profile.
    Next step was aligning the Linearrail of the left Y Axis which was pretty simple. Just mounted a dial gage to the slide and drove along the screws. A little pressure here, some more pressure there to get it near zero.
    Just another extrusion/Aluminium CNC-11b-jpg
    Just another extrusion/Aluminium CNC-12b-jpg
    Last step was inserting the fastener caps. After inserting them I used a razorblade plane to cut away the overhang.
    Just another extrusion/Aluminium CNC-33-jpg
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-22-jpg   Just another extrusion/Aluminium CNC-21-jpg   Just another extrusion/Aluminium CNC-11b-jpg   Just another extrusion/Aluminium CNC-12b-jpg
  12. #12
    Activation process umfan110's Avatar
    Jun 2018
    What kind of couplings are you using for the nema 24's and the threaded rods?
  13. #13
    Quote Originally Posted by umfan110 View Post
    Simple 30mm diameter jaw couplings.
    https://www.cnc-discount.com/wellenkupplungen/122
  14. #14
    The Y Axis is aligned. The Ballscrew for the X Axis arrived today.
    Just another extrusion/Aluminium CNC-main1-jpg
    To make things more rigid I mounted a 120x80 Profile to the back.
    Just another extrusion/Aluminium CNC-detail-jpg
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-main1-jpg   Just another extrusion/Aluminium CNC-detail-jpg
  15. #15
    Aligned the X Axis:
    X left:
    Just another extrusion/Aluminium CNC-xleft-jpg
    X center (after tightening the slave rail it changed to 0.03mm which is still fine for me):
    Just another extrusion/Aluminium CNC-xcenter-jpg
    X right:
    Just another extrusion/Aluminium CNC-xright-jpg
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-xleft-jpg   Just another extrusion/Aluminium CNC-xcenter-jpg   Just another extrusion/Aluminium CNC-xright-jpg
  16. #16
    Just a small update. It is almost done.
    Attached Thumbnails Attached Thumbnails Just another extrusion/Aluminium CNC-chain-jpg   Just another extrusion/Aluminium CNC-full-front-jpg   Just another extrusion/Aluminium CNC-fullb-jpg
  17. #17
    Hi. Today I recognized that the stepper drivers were not connected to the +5V Terminal. Only the step- and dir- was connected to the board. But step+ and dir+ were not connected to anything. The stepper worked.
    Could someone explain why it worked?
    The drivers are DQ542MA, wired active low, but I forgot to connect the +5V.
