Why not test to see how much it moves? Clamp the rail down, bolt on an extension to the carriage that approximates the distance where the center of the spindle will be, apply a side load, and use an indicator to measure the deflection.
Hi all,
I've been using my CNC router and love it a lot, but I have a few linear carriages and rail sitting around gathering dust, so I thought about building a LIGHT duty engraver/router for wood only.
If I had my Z axis on one 20mm/25mm rail only (with two carriages), how resistant to twist would they be due to side forces when milling across the table? Bear in mind the length of that rail will be 320mm or less and it is 25mm rail. The carriages are THK and INA. Having one rail only would keep my z axis quite narrow, allowing me more x axis movement.
Neal.
What the rail is mounted to may have a large effect on how rigid it is.
UCCNC 2017 Screenset
