Need Help! table wooble
Results 1 to 5 of 5
Thread: table wooble
    Default table wooble
    hi i just finish build my machine i can set around 3000 acc but the problem is my table wooble even at 1500acc ..its because im using lock wheel for my table is there any suggestion how to stop the wobble? im thinking to use 4 car jack for it
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: table wooble
    Hi Team - Send a photo of the issue.. Whats a lock wheel ? and acc? (acceleration? what units)Peter
    Quote Originally Posted by peteeng View Post
    hi sorry to elaborate more its Caster Wheel with lock and accelration unit is mm i think since i set my native unit in mm my velocity around 10k and acceleration around 1500 for now i can go higher but the table wobble mostly when gantry move.. x axis is fine
    Jul 2018
    dum dum
    Hi Team - So its acc = mm/s/s? and vel =mm/min? Is the table the only wobble or is the machine jerky? ie if you sit on the machine table or put something heavy on it does the wobble stop? You need to establish if the machine is wobbly (due to programming or mechanical issues) or is the table wobbly??? Peter 10m/min is not really fast and 1500mm/s/s is high for some machines so slow that way down say 300mm/s/s and see what happens.
    If its the table then it needs to be stiffened and weight added or screw it to the floor or all of the above
    If its the machine then it needs to be stiffened, fixed or whatever is needed. Cutting back the acceleration is all that you may need to do.
    Peter
    Peter
    thanks for suggestion yes i can set it around 1000mm/s/s its work fine without wobble. just now i tried to put 2 floor jack to the table ,the wobble is reduced almost 80% .maybe because its caster wheel bearing got play. just thinking to put 4 floor jack to my table i still need the wheel for easy maitenance since i have small room
table wooble
table wooble
