New Machine Build GME's New 80/20 CNC Build - My Design - Page 30
Page 30 of 33 FirstFirst ... 2027282930313233 LastLast
Results 349 to 360 of 386
Thread: GME's New 80/20 CNC Build - My Design
  1. #349
    Apr 2016
    Default Re: GME's New 80/20 CNC Build - My Design
    Quote Originally Posted by Sterob View Post
    Well done Gentlemen.
    Seems like a great result.
    It was like reading a exciting novel with those posts....lol
    Thank you, Sterob. It's been an adventure.
    All the credit goes to Peter, who devoted an extraordinary about of time and effort to finding a fix. I can say with absolute certainty that I would not found the solution without him. As I've made clear throughout the process, I have dealing with an issue that is far outside my knowledge and experience.
    I've never seen any mention on the zone about using something as simple as nylon washers for vibration isolation. That leads me to believe that I'm not alone in my ignorance on the subject. Hopefully this thread will help others find a solution to similar issues. Stepper vibrate - just the nature of the beast. I suspect there are a number of folks who have experienced the same or similar issues, but ended up just living with it. Now, there is a pathway for them. IMO, Peter has done a great service to not only me, but to others in our CNC router community. Thank you again, Peter.
    Gary
    The Old Man and the C -----NC
  2. #350
    Jan 2005
    Quote Originally Posted by GME View Post
    Gary
    Glad you found a fix, this is standard practice in the industry to use plastic or urethane bushings / washers when you want to isolate something like this, it would even be better if you changed the bearings also to a AF Delrin bushing, which you would have to custom make, having Bearings in something like this is a bad design
    Mactec54
  3. #351
    Apr 2016
    Thanks, mactec. Delrin AF bushings sound like a good idea, especially given what I've learned lately about plastics. Without tearing down R&P drive, I can only guess at the OD of the eccentric bearing. I'm guessing it would take a fairly large diameter rod, and Delrin AF is very pricey, even for a short piece.
    I won't quarrel with you about the design aspect, except to say that these R&P drives were designed for use in a kit for the DIY market - and at a price point. It may be a poor design, but it works well enough for its target market.
    FWIW, it looks like Avid CNC dropped the ball bearing in the drive pulley/pinion and moved to a Super Oilite bushing. I wonder if replacing this bushing with Delrin AF would also be a good idea?
    If only I had a lathe . . . . Maybe next year! A lathe is on my wish list. Cutting some custom bushings would make a good project and skill builder, and would improve my machine.
    Gary
  4. #352
    Jan 2005
    Gary
    If you were to modify it at anytime you would fit a aluminum bushing and then this would cut down the diameter of the AF Delrin Bushing size to be made, the pinion end is where a good bearing setup should be, it's a rolling element the fixed end is basically static, which is not a good place to have a Ball Bearing
    You would make 2 Delrin Bushings with a flange, this would give you the washer on both sides for total isolation, so you would make 2 Bushes with a flange
    Attached Thumbnails Attached Thumbnails GME's New 80/20 CNC Build - My Design-plastic-bushing-png
    Mactec54
  5. #353
    Apr 2016
    Thank you for the design tip. It would be much less expensive starting with aluminum for the bulk of it, and then machine the Delrin in a smaller size. Now I have a basic model to work from. I appreciate the additional information.
    Gary
  6. #354
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Morning Gary - Happy to be of help. Been interesting wading through the issue so far away. I use a lot of delrin in place of aluminium in mining equipment. You could make the arm in delrin (would need to be a bit thicker) and then it would be an excellent isolator. Then you can integrate the bearing into it. Plus this is a mill job Happy Making. Peter
    I've just launched my website! Tetra Motion - TETRA MOTION
    - - - Updated - - -
  7. #355
    Apr 2016
    Quote Originally Posted by peteeng View Post
    - - - Updated - - -
    Making a new R & P drive in delrin. Now, that's an interesting idea. I'll have to give that some thought. I have a mill and CNC router, after all.
    I like your new website, Peter. I didn't realize you were designing Maxiumus in anticipation of starting a business venture. I'm sure it's going to be a big hit in Australia. Depending upon the costs to ship parts to the U.S., you may have a hit here as well. The best of luck!
    Gary
  8. #356
    Jul 2018
    dum dum
    Hi Gary - Any new squeaks to solve? I've been working on Tetra Motion for about 2 years as a back burner project. But it's time has come, so launch I have? (as Yoda would say) Peter
  9. #357
    Apr 2016
    Hello, Peter,
    No new issues. The machine works great. I'm finishing up my spoilboard and will then get on to the gussets.
    I did a search for Tetra Motion and found nothing to link it to your website address, https://cncrouterkits.com.au/. Then, I used the search terms (Google), "CNC Router Kits.," which I believe is reasonable for someone interested in a kit machine. I gave up looking for your site on page 10 of the results. Your site wasn't listed. That's a bad deal. People won't find you. Also, I'd be reluctant to put your company name, Tetra Motion, out there without providing a link to your website. No better luck searching for Tetra motion. If you just point to Tetra Motion, no one will find you.
    I wish I had some sage advice on how to improve your online presence, but my internet talents are limited to being a reasonably competent consumer. I know nothing about establishing and growing an internet presence, except that you have to have a presence people can find. Unfortunately, at this point, you don't.
    Gary
  10. #358
    Jul 2018
    dum dum
    Hi Gary - It's only been up a week so the robots and algorithms haven't done their work yet. Takes about 6 months before these things work through the system in my experience. So be patient and eventually you will be able to type those words in and get the site. But as you know it's Tetra Motion - TETRA MOTION
    ... simples. I do test searches weekly and I'm setting up site metrics to figure out where and when people are looking at the site. Takes time to gather info, understand what's happening or not happening then redesign or adjust the site and links to suit. Just as much work as designing a router
    I just put in Tetra Motion CNC and got this. I got the CNC Forum announcement, my facebook page and two pages from cncrouterkits, so Googlebots are chewing their way through the site. 1.11 billion results!! staggering
    Attached Thumbnails Attached Thumbnails GME's New 80/20 CNC Build - My Design-tetra-1-jpg
  11. #359
    Sep 2005
    It will take longer than a few weeks, more likely maybe up to a year with mine. I have discontinued my website as its time to really retire as I am 76. I will keep my FLA CNC Router for now and do interesting jobs and stuff for my Church but no more timelines. If your using Your computer and ISP to judge its not a true statement of what your going to get.
    Try from another computer not on your ISP or even your city and google will log that Search.
    Gary, I am glad your making progress, getting done just in time for Christmas gift giving!!
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  12. #360
    Oct 2004
    For website analytics, check out Google Analytics or Microsoft Application Insights. With both you add a small amount of code to your website and it tracks page hit statistics and other info. They both give you a portal where you can view the statistics. Both are free but not sure if MS insights requires hosting the website on Azure. Read up on SEO (search engine optimization) to find out how to add tags to get more page hits.
