Why did my Hall effect switch trigger position changed
Results 1 to 12 of 12
Thread: Why did my Hall effect switch trigger position changed
    Member TTalma's Avatar
    Jan 2013
    Default Why did my Hall effect switch trigger position changed
    I use hall effect trigger switches for each of my axis. Yesterday I ran my machine and everything ran as normal. Today I noticed that my machine seemed to be cutting deeper. I checked everything out. And I noticed that my Z axis which used to trigger at a point of 6.959 above my table now triggers at 7.0469 above the table. A change of .0879" over 1/16 of an inch different.
    I trigger from a steel bolt through the face of my z axis, and a hall effect through the face of the Z mounting plate (Top down pic included, couldn't get a good side view pic). Both the sensor and the bolt are still tight.
    So how could the trigger point have changed with nothing else changing?
    Why did my Hall effect switch trigger position changed-2019-04-14-11-15-54-jpg
    Dec 2003
    Default Re: Why did my Hall effect switch trigger position changed
    Are you sure the distance from prox sw head to trigger point has not changed?
    Jan 2005
    Is it a Hall effect sensor or actually an inductive proximity sensor?
    A Hall sensor should use a magnet as a target. A proximity sensor can use just a metallic target. For either it is best to have a target that is as large as the sensor face or larger.
    Dec 2003
    Quote Originally Posted by 109jb View Post
    Although technically a proximity sensor is a hall effect sensor, just difference in the construction as to the form the trigger method used. The Prox sensor generates its own magnetic field.
    Al..
    Nov 2011
    Magnetic fields attract chips (which generate more magnetic fields).
    Don
    Mar 2003
    Shelby Township
    They don't attract wood chips.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  7. #7
    Feb 2008
    Quote Originally Posted by ger21 View Post
    Ironwood?
  8. #8
    Jan 2013
    Quote Originally Posted by Al_The_Man View Post
    While I can't be absolutely sure I checked both the bolt that I have sticking out and the switch (I guess technically it is a prox switch) are tight, There is dust on them, and no evidence that they moved.
    This mainly affected my tool changer. I have a Z height depth setter. But a couple of tools are 1/16" above the table and I use G53 (Absolute position relative to homing switches) commands to swap tools. And I first noticed when one of the tools was dragged against the table.
  9. #9
    Jan 2013
    Quote Originally Posted by DonKes View Post
    Don
    I haven't cut any metal with this machine. And I did look for metal chips, and didn't find any. I also used my air gun to clean it off, and no difference.
  10. #10
    Dec 2015
    I had my Z axis inductive proximity sensor go bad and as a result it was doing what you have described.
    At first I just thought the trigger target had moved or maybe that my tool had moved in the collet, but after a few minutes of trouble shooting it was obvious the Z wasn't referencing the same point. I readjusted, remeasured a tool, made some stuff, then the next day it was out of whack again. I replaced the sensor and have been good since.
    I'll add, occasionally aluminum chips trigger my Y axis inductive sensor. It's the damnedest thing. Not sure if it's an interaction with my coolant or what, but that should be impossible.
  11. #11
    Dec 2003
    Quote Originally Posted by CL_MotoTech View Post
    There are also types that operate with non-ferrous metal.
    Oct 2009
    I can see only three variables if it worked before:
    1. Something with the trigger system has changed (moved, dirt/chips, got magnetic) - You say no.
    2. Something has happened with the sensor (hit, got bad, EOL) - Replace.
    3. Something has happened with the supply voltage (different sensitivity) - Check.
