What do you have the current on the drives set at?
80ipm is only 160rpm. You should have plenty of torque at that speed.
Are the screw and nut perfectly aligned? Even a small misalignment can cause binding.
Of all the places, the ones at Home Depot worked best.
You can find more pics at my thread:
https://www.cnczone.com/forums/diy-c...h-top-cnc.html
UCCNC 2017 Screenset
No, it probably shouldn't be that tight. Oiling it should definitely help.
OK after adding the pneumatic tool oil I was able to get it up to 360 IPM safely. It stalled at 400.
Increased the acceleration to 1200 an it seems nice and fast now.
Is that good now?
I would think so.
5x faster is quite an improvement.
I have the same motors and screws for the dual Z axis machine I'm building, and was hoping for ~400ipm. I'm using AM882 drives and 60V.
And my Z axis won't weight more 20-25lbs.
2.2KW round air cooled.
This is good to hear.
Honestly I must be slipping here because one of the first things I do at work on a failing axis is to try turning the leadscrew shaft. I’m surprised by how much turning resistance you indicated before lubrication. It does seem excessive but your lube has apparently cleared that up. This highlights the importance of maintenance, a good operator makes sure his machine is lubricated before the start of his shift.
By the way I’d make sure that you can easily lube all of your machines axis. Sometimes the best solution is a pipe or lube tube ran to the bearings or nuts.
My Z axis are pretty compact. And half of them are plywood.
Very nice Ger21
What program did you draw that in Ger21, nice cad work.
Fusion 360.
