.0001" Accurate gantry CNC design suggestions?
Results 1 to 13 of 13
Thread: .0001" Accurate gantry CNC design suggestions?
    Member Thunderskunk's Avatar
    Aug 2018
    Ct
    Default .0001" Accurate gantry CNC design suggestions?
    Hello gents,
    I am looking for a CNC router design that is really stinkin accurate, and I definitely need some help on this one.
    This forum is bloody huge! I drooled over CNC routers as a kid, but I ended up as a CNC machinist and then an engineer for an EDM shop. I have a fanuc robodrill in my basement, which somewhat dampens the desire to build a CNC router, haha. Still cool that folks make em themselves.
    I am on a different quest. I fully understand that a router with a .0001" resolution would be... well, fairly pointless. What I need is the base to build a Coordinate Measuring Machine (CMM). I haven't seen any cheap already-made machines that fit the description, and there's a lot of things I don't need for a CMM that a router has.
    Full-fledged CMMs are not cheap. With good reason, but there's definitely no low-end version. My idea is to take a gantry DIY CNC router minus the router, add a wired probe, use Mach3 with a probing routine, output the measurements in CSV, and use excel to generate a report. Heck, you can even use encoders for position.
    If I can build it cheap enough and make it WORK (key word), even if the results are garbage, I can build a platform that is more rigid and square using a surface plate and some granite straight edges.
    Anyways, let me know what you guys think. Thanks for the help!
    Matt
    Member routalot's Avatar
    Dec 2003
    Default Re: .0001" Accurate gantry CNC design suggestions?
    I thin you will need to build a standards room to house it.In any other environment a draught through an open door will probably cause enough thermal movement to throw doubt on such desired levels of accuracy.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Every motion component needs to be of the highest quality, if you need that kind of accuracy. Ultra precision linear bearings, precision ground screws. These parts will be extremely expensive, unless you can find a good deal on Ebay.
    And I would think that the frame needs to be precision ground as well?
    UCCNC 2017 Screenset
    Sep 2005
    Quote Originally Posted by ger21 View Post
    Gerry I think he also said "Cheap" so I guess he needs to decide. There was someone on here building on a granite plate perhaps he can help.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Aug 2018
    Ct
    Quote Originally Posted by wmgeorge View Post
    And that's exactly it. If I had 10k to spend, I'd get a CMM and call it a day.
    Step 1 is getting a CNC router to output data like a CMM, regardless of accuracy. Step 2 is making said system more accurate. The easiest way I can think of is to use a surface plate as the base, granite parallels as the ways and gantry legs, possibly with home-made air bearings, and go from there.
    But as mentioned, if there's a design or even prebuilt router that claims to be the least bit accurate, it would be easier and faster for me than starting from scratch.
    Mar 2003
    Shelby Township
    A $150,000 router is not even close to being that accurate.
  7. #7
    Dec 2013
    Here are a couple of good starts, at least the base machines are there so the hard work is done.
    https://www.ebay.com/itm/Renishaw-Cy...O62:rk:47:pf:0
    https://www.ebay.com/itm/BENDIX-CORD....c100005.m1851
    Jim Dawson
    Sandy, Oregon, USA
  8. #8
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Jim Dawson View Post
    I agree you can find some good deals on Ebay for this kind of machine, even if it is not working the main building blocks are there
    Mactec54
  9. #9
    Aug 2018
    Ct
    That's probably where I'll end up. Definitely going to buy the real thing, inspected and refurbished by someone who knows more about CMMs than I do. Alas, we need more $.
    Here's a specific question. I've been getting input from Jim on an older thread on a similar subject, but I'll focus it here.
    With the potential to end up using encoders, I'm steering away from Mach3 and toward KMotion. Is there a thread that breaks down the details of building a CNC router using a KFLOP board and KMotion software?
    I'd like to test the functionality before the accuracy, and the cheapest way I think would be to get the electronics and drivers plugged in to a cheapy-Chinese router with a cruddy spindle probe, then work my way up from there. I'd love to piggy-back on a design and parts list someone has already made work.
  10. #10
    Dec 2013
    This might be helpful https://www.cnczone.com/forums/dynom...int-cloud.html
    You should be able to buy any cheap router kit and hang the KFLOP on it for testing. The Dynomotion website has all of the setup documentation. You just need to decide on using steppers or servos for testing.
    Jim Dawson
    Sandy, Oregon, USA
  11. #11
    Aug 2018
    Ct
    The guy that made a granite CNC:
    So, I'm going to straight-up conclude: No. This doesn't work. At least not in my budget.
    My ultimate goal was to have parts inspected while I was away from the shop, or lights-out inspection. It's not that it can't be done, and that I won't do this at some point in time just to play around, but I'm going to join the many voices I've heard over a few forums and say this isn't the project I want to get in to right now. I'd love to toss a few K at the project and get something that's semi useful. At the very least, I need a surface plate, and I'm sure the components would sell after the fact if it didn't work, but I'll never get back the hours into programming something I'm not all that knowledgeable about. Hours better spent making money with my mill. A good few months with the mill might even pay for a CMM, and those dollars gone towards tools and holders will multiply faster than my home-grown CMM will.
    Maybe somebody like Tormach will see the niche market and make a $10,000 CMM for simple, low tolerance inspections. But maybe not.
  12. #12
    Dec 2013
    Quote Originally Posted by Thunderskunk View Post
    No reason you couldn't use a mill for a pretty good (not a great) CMM. Should be able to get into the +/- 0.0005 range depending on the resolution of the machine.
    I have thought about adding CMM capabilities to my mill. Not much of a step in my case, I already have 1 micron scales installed and run it with a Galil motion controller, so all I need to do is write the software and buy or build a decent probe. Maybe I'll get ambitious and write the software. Been thinking about ways to make a really accurate probe. It should be able to use the G code to compare the expected shape to the actual part and log any deviation. Not to difficult. The main problem is that my shop is not temperature controlled so real accuracy is not possible.
    Jim Dawson
    Sandy, Oregon, USA
  13. #13
    May 2005
    Hello gents,
    The cost for accuracy goes up dramatically compared to the average CNC being built here. That is even if you have a well equipped shop already to allow for precision machining of the machines components.
    CNC routers are one of the few machines that are easily built by DIY types and actually be extremely cost effective over a commercial build. So there is a huge attraction to DIY routers due to getting a lot of capability for a small outlay (relatively). Building a DIY CMM is a different story all together. Frankly you could buy a Datron and still not be good enough for a CMM depending upon the required accuracy. Which brings up the question of how much accuracy is really required.
    A router with 0.0001" resolution isn't pointless at all, it just isn't the domain most builders on these forums play in. Note that resolution isn't precision so I'm hoping this isn't mixed up. If you are looking to build a CMM I'd first look for a used machine. These come on the market rather regularly as the electronics and software quickly become unusable in modern facilities. The problem with CMM's is software which is well beyond trivial. While this is an off the cuff guess I suspect that the software will require ten times the effort required to build the mechanical systems.
    Sounds to be extremely hackish. I would suggest a combination of C++ and Python to build the software infrastructure. Even then you would likely have years ahead of you, especially if you want the lights out operation as mentioned elsewhere. At this point I wouldn't even get near Mach 3 for a new project.
    As for the costs, low volume and high precision are expensive. You might actually be able to control costs if you can accept less accuracy. If you have production parts sometimes alternative metrology approaches can be less demanding and frankly more reliable.
    A simple machine should be fairly easy to make work assuming you can find a reliable probing head. Work in this context would be a machine that can take a reading if you manually guide it to the surfaces in question. That is send the machine to a surface of interest, run a probing cycle and capture a positional reading or two. It gets a lot more complicated to collect data from arbitrary surfaces and then generate surface profiles and feature measurements.
    In fact you may be able to find some of the simple stuff done already out there on the net.
    Matt
    This is actually a very interesting endeavor you have here. I just have visions of whole teams of programmers trying to work on the software for such a machine. Software is a two edge sword here, there needs to be much effort put into post processing to get valid reports. This especially measuring anything beyond the trivial. Likewise you will need to generate NC code at the front end of the data chain to actually collect the data in the first place. If you don't have code to simplify data collection that will mean manually coding a huge number of data probes.
    You are right to start out on a simple machine and frankly you don't always need the high precision that common CMM's offer to get good results. This would allow focusing on software which in my mind is the real challenge.
