Build Thread First Cnc Build With extrusion - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Thread: First Cnc Build With extrusion
  1. #41
    Default Re: First Cnc Build With extrusion
    yeah now just need to fix the spindle holder plate because its too low
  2. #42
    What size are your energy chains?
  3. #43
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    1.JMC SERVO 20BIT 400Watt
    Power: 400W
    Speed: (Rated/Max) 3000/5000rpm
    Price : 190 USD EACH WITH THE DRIVER
    Do you have an online source for these servos, at that price?
    Are these the same?
    https://www.ebay.com/itm/263257465942
    UCCNC 2017 Screenset
  4. #44
    Quote Originally Posted by ger21 View Post
    Are these the same?
    yes that right the difference is i use 20 bit incremental not 20 absolute they have 2 version maybe you should ask them for incremental since i got it that cheap you can contact jmc directly same as mine they can delivery via fedex
  5. #45
    my first cut test still playing with speed cutting cast acrylic 12mm axial 3mm radial 50 ipm
