...a guitar neck out of red oak. 3D work done in Fusion 360. This is my first 3D neck and I'm happy with the way it turned out, although I have some tweaks to do on my CAM workflow. I've built a bunch of necks out of red oak. It's a bit chippy, but otherwise makes a great neck. Two way truss rod and dot markers from ebony Timbermate grain filler.
About that super glue finish, what is the trick there? Generally I don’t like seeing super glue on my wood work as it leaves a rough milky white surface. Are you using something thinner than normal super glue to get penetration?
