Need Help! cnc router problem
Results 1 to 7 of 7
Thread: cnc router problem
    Registered dave243's Avatar
    Feb 2019
    Default cnc router problem
    hi all i have an older ooznest ox cnc router table seem to have sorted out most of the mechanical problems but i am having a recurring problem which mite be the control board or software not sure when cutting it will stop when cutting a job and the gcode sender crashes also is there an alternative to gcode sender that will work with my old control board
    thanks Dave
    Sep 2005
    Default Re: cnc router problem
    Gee... Let me try to guess what control board and software your using? I am thinking really hard and I will get back to you with an answer. Oh I am going to have to try and guess what computer and OS, that might take some more time.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Feb 2019
    Quote Originally Posted by wmgeorge View Post
    ok right using G code sender soft ware to run the board
    the control board is CNC xpro
    running off a laptop with win 10
    May 2005
    Quote Originally Posted by dave243 View Post
    Well is the dork even compatible with GCode Sender?? I generally think of UGS as an Arduino solution in conjunction with GRBL.
    As for Windows 10, sadly I’m of no help there as I would never run that OS if there are alternatives.
    Sep 2005
    Thats a basic hobby grade board, all in one GRBL. Unless you have a perfect location with clean power, and no EMI it will pick up electrical interference and crash. I had something like that on a blue light diode CNC it ran slow and crashed a lot. Windows 10 is not a good OS for hobby grade systems. Yes you can make it work if you know how, but its not worth the effort. I use Windows 7 Pro on all my machines. There are some control systems made for Windows 10 and they work fine. Acorn is one, do some google searches.
    http://www.spark-concepts.com/cnc-xpro-v4-controller/
    Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication.DIY CNC kit
    Feb 2019
    thanks i will look in to this now I have a rough idea where i am heading now thanks
  7. #7
    Jun 2015
    Sweden
    thanks Dave
    If your board is LPT (printer) port pinout compatible then an alternative is a UC100 USB or UC400ETH or UC300ETH ethernet motion controller. They all work with 3 softwares, mach3, mach4 and uccnc. The software used is your choice.
cnc router problem
cnc router problem
