cnc router problem
Results 1 to 13 of 13
Thread: cnc router problem
    Registered dave243's Avatar
    Feb 2019
    Default cnc router problem
    New to cnc cutting i am have problems with my cnc table it seems to be cutting 2mm shorter on the Y axis not to shore how to solve this or where to start hope i have put this in post in the right place and help would be gratefully received thanks Dave
    Member awerby's Avatar
    Apr 2004
    Default Re: cnc router problem
    Have you verified that your steps per unit settings are correct on Y? Have you checked the backlash?
    Feb 2019
    i have set up as per instructions that came with the cnc not sure about backlash what this is (very new to this)
    setting i have are
    $100=26.667
    $101=26.667
    Member routalot's Avatar
    Dec 2003
    What type of mechanism moves the axis?If it is belt driven,there is the possibility of a bit of slack in the belt.Maybe you could post an image or two of the troublesome axis components.
    Feb 2019
    hope this works
    Attached Thumbnails Attached Thumbnails cnc router problem-img_20190213_173820-jpg   cnc router problem-img_20190213_173851-jpg
    Jan 2008
    did you change the y steps to the same as the x
  7. #7
    Feb 2019
    they are exactly the same as it is a 1500mm x 1500mm machine and here are the settings that can with the machine
    Attached Thumbnails Attached Thumbnails cnc router problem-img_20190213_193852-jpg
  8. #8
    Jan 2008
    The y and x are different normally they should be the same
  9. #9
    Dec 2003
    Quote Originally Posted by fixtureman1 View Post
    To my eyes,the x and y values are the same with the exception of the maximum travel.This probably reflects the different lengths of travel on those axes on the sample machine.
    Looking at the photographs of the machine It is clear that it relies on a toothed belt for motion.I would begin by checking that the pulleys haven't worked loose and that the belts have no slack as either of these things could cause the backlash that was mentioned earlier.
  10. #10
    Aug 2014
    Quote Originally Posted by dave243 View Post
    Check the drive belt pulleys have their grub screws done up tight.
  11. #11
    Jan 2008
    thenumbers are not the same. change the y to the x number $100=26.667
    $100=26.667
    $101=26.667
  12. #12
    Dec 2003
    $100=26.667
    $101=26.667
    Those are the numbers I am seeing.The discrepancy appears to be the $130 and $131 which don't correspond to a table of 1500mm X 1500mm ,but I suspect this is derived from a specimen setup sheet.I feel quite sure the problem has it's source in something mechanical.
  13. #13
    Feb 2019
    i have know i dear how to move this to the right place and to the people that have helped thanks the, x y limits are different but the step/mm are the same
cnc router problem
cnc router problem
