Would this be a good shielded cable for 220V VFD and 220V 2.2kw spindle set?
https://www.aliexpress.com/item/Farr...b-ea610ae1e7c2
If so, which would be the correct Gage?
If not, please point me in the correct direction.
Why would you buy an unknown brand of cable, with no spec's I posted what cable you needed in the Parameter Post I don't recommend any other Shielded Cable unless you have the specs it looks ok and appears to be double shielded but has no flex rating or voltage ratings the IGUS cable you can get it right away it's more expensive but German quality cable
From the other post
For your spindle Connection cable required ( IGUS CF6-15-04 ) ( Ph 401-438-7270 )
Mactec54
#16 AWG is rated for 10 amps. It could be pushed a bit.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
It depends on the temperature rating of the wire.
Mactec54
Yes it sure does if you understand how it all works, you are starting your BS again
Not at all I have had it inspected many times, you are not dealing with regular cable you can by at the local hardware store, I have exported machines all over the world which most have higher standards than the NEC regulations require as far as cable goes
Mactec54
Buying mains cable from a supplier that doesn't give you at least the voltage rating is not a good idea. We use Lapp cable on some of our machines, they very good...
Yes they most likely come out of the same factory...
Look it up. The US has the most strict regulations in the world. We had to routinely rewire machines not up to NEC regulations. Just because some factory worker wires a machine with not Code wire does not make it right. There are exceptions for cable trays installed in an industrial applications.
FYI you can make and wire anything you want and there is no inspection for Export. BUT when it gets to the destination it has to pass Insp.
Look it up.
Not True, correct with the last part of inspection at destination that should be mandatory everywhere but it is not, NA has the worst practice of this compared to other countries, these Chinese Spindle are an example of that, with no Ground connected on 90% of them
I have been through this process and doing this since the 80s, and are quite sure you have no clue what is involved, it has to be approved also before export, nobody wants to export something to another country and have to rewire it when it arrives, the only time I have had a problem was when I had fitted a 120v transformer instead of a 230v, so I solved that problem by making all new Transformers dual Voltage, this was for powering electronics so was a very small 2A transformer
NEC has a cable requirement you will see that are no different than any other country, the cable spec I proved exceeds the NEC requirement for these Spindles and no inspector would fail it like you have said
Mactec54
Anyone can look up what I posted, just grab a copy of the NEC and find the sections I posted above. Quote the section of NEC Code your reading about approved cables, you do have a copy don't you?
So what big company do you work for Mac? They must not have any business if your posting on CNC Zone all the time? Hope you don't lose your job when they find out.
