If you tell us where you live what country ??? which by what you are saying is NA if you have 120v supply so yes you can install it if you live in NA
Your connection would be to the VFD Drive 120v ( R ) Hot and Neutral to ( T ) Ground to the Ground terminal
You will need at least a 35A circuit to supply enough current at 120v
The VFD to Spindle connection is U V W
U=Pin1
V=Pin2
W=Pin3
and Ground to Pin 4
Mactec54
Please be aware that I'm in the US, not UK, did I mislead you?
The reason I originally bought this 110V setup was because they had a pic showing it basically wired to NA 220V (2 120V hot lines) which is now clearly wrong for this setup.
I did not think that the standard 220V VFD they normally sell would work in NA, because other countries (like the UK) use only one 220V line and a neutral instead of two hot 120V lines like we do to get 220V (240V).
I only realized that I actually bought a 110V (120V) setup after I read a post on CNCzone which a guy basically bought the same I did and blew up his VFD because he wired it with 2 120V hot lines = 240V as the "pic he also found" showing it wired that way. It should have been wired as 120V only with a hot 120V and a neutral (not two hots) as was shown.
I found the following on aliexpress:
Technical Features:
Input & Output
Input Voltage : 110V, single phase or three phase
Input Frequency: 47-63Hz
Output Voltage : 110V, three phase
Output Frequency: 0-50Hz / 0-400Hz
I have no idea what is true... but they claim Output Voltage : 110V, three phase
I read on CNCzone that there is no such thing as 110V 3 phase... Is there such a thing?
I'm including some info I got to see if ANY of it makes sense.
I included a pic I made of what I now think the wiring is supposed to be.
Needless to say I'm very disappointed with myself for this purchase.
Well regardless of what you have been told you have 110/120 3 Phase motor as your looking at it and holding it. Just a reminder that not everything posted on the Zone is true!! So get some #10 stranded wire and a 30 amp 120 volt breaker for your circuit breaker box and your in business, Hook up as they tell you and same for your motor. Use #14 stranded wire and it should be the special wire extra flexible and shielded wire made for spindle wiring. It has 4 wires, 3 for hot and one for grounding and its shielded. Its going to be a bugger soldering that wire to those little pins inside the plug connector. I used a short piece of cable and soldered to the pins and then ran to a small junction box on the Z cartridge and then spliced to the long lead going back to the VFD box.
Buy yourself a good DVOM and learn how to use it. You will find out quickly your two 110 volt lines coming in are actually 220 volts Line to Line. UK is two wire also, and its 220 across those two incoming lines, but only one wire is hot referenced to ground. Hard for us here in the USA to understand, but thats the way it is. You will also find out its not 110 but more like 115 or 120 to neutral or ground. Mine reads higher than that. You will also find its not 220 but more like 240 or more line to line. Been that way a number of years.
Reminder you really only have,,. what a 1 1/2 Hp spindle.
Mactec54 can help you with the setup
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
What you read is true the Voltage you put in is the voltage you get out, apart from Parameter changes which can change the voltage slightly
No there is no such thing in NA this is a Chinese made 110v 3ph spindle to make a sale in NA tricking the buyer
I posted for you what the wiring needs to be for a 120v connection but even you VFD is not the real thing so at the point until I see more details of the VFD drive, do you have the manual for the VFD
Your VFD is not the real thing also that is a copy of the HY but what copy do you have, you need to make everyone aware of where and who you brought this from so hopefully they don't buy from this dealer
Mactec54
I bought it in 2017 from aliexpress.com
The Store:MASTER JIANG 1SMT
I don't see him selling what he sold me anymore, but here is the link to his store:
https://www.aliexpress.com/store/321...7e054e94INhWxV
Thank you for the wiring info.
I do have a manual. What do you need from it?
Same advice I gave before. Buy youself a decent DVOM and learn at least how to read voltage. It makes no difference to the drive how you get the 220 volts. Between the two wires in the UK its 220 volts, between the two hot wires in the US its 220 volts. It may read 110 each side to neutral or ground / earth but you do not care about that. This question comes up All the times with imported laser machines. Mactec 54 has got it right on the strictly 110 v only VFDs and odd ball 110 v 3 phase spindles they are junk.
that spindle made by changzou jianking company
if weren't sure ask them
wf021021@163.com
or Skype
Skype:wf861203
please note what is engraved valuses on spindle they are the right parameters you using when you set up the VFD
huanyang drives are fairly simple to set up
im sorry the right name is huajiang
heres an original pdf for huanyang drives
page 7 declare that
The 220V power source may turn on RST willfully two phase.
this should help you deciding if you can feed 2 live on RST
http://www.jinlantrade.com/ebay/invertermanual.pdf
yes, try again to read...
page 7
heres your question
Would you simply connect the (2 )120V lines where they would normally connect their (1) 220V and (1) neutral wire to?
I forget to say
you can see a line in the post , should shown in blue
move over the pointer then click
it should redirect your browser to the page and open a pdf
You are making this more confusing than it has to be you don't have anything to do with 220/240v power supply so don't talk about it, your VFD Drive is 110/120v and your spindle
The VFD you have I need to know what the spec's are what was just posted is not for your VFD Drive go to any page in your manual where there are some parameters and do a copy and post it here, I will have the manual and can give you the Parameters you need to set
So by posting this photo this I will know what VFD Drive copy you have, the Parameters are different with every VFD Drive the copied VFD Drives some work ok but are nothing like the real thing
Mactec54
