None of the above is going to do what you want, U V W and you will smoke your spindle, there should never be any type of switching in the U V W connections for these spindles
You can use the fault circuit
PD052=02
FA FB FC connected in the EStop circuit this would be NC and open when there was a fault
Or just connect in the same circuit in the FOR and DCM On / OFF circuit
