David A's New 2x3 Bench Top CNC - Page 58
Page 58 of 61 FirstFirst ... 84855565758596061 LastLast
Results 685 to 696 of 727
Thread: David A's New 2x3 Bench Top CNC
  1. #685
    Oct 2009
    Default Re: David A's New 2x3 Bench Top CNC
    CORRECTION!
    Sorry about the typo.
    Email to Teknic has been corrected as well.
    With the servo enabled, the voltage between the “measurement points" reads 0.197 Volts.
    With the servo disabled, the voltage between the “measurement points" reads 4.96 Volts.
  2. #686
    Oct 2009
    No email yet from Teknic.
    In the meantime, I will resurface the BB ply spoil board.
    I will use a 1.5" Freud surfacing bit and I will also run the
    DC while doing it but without any brush, just the two DC
    hoses to see just how much dust and debris it captures by itself.
    The two hoses (pipes) are about 4-1/2" above the cutter:
    David A's New 2x3 Bench Top CNC-img_8025-jpg
    To see the remaining dust and particles, two black painted
    plastic strips are placed to the front and the side:
    David A's New 2x3 Bench Top CNC-img_8024-jpg
    David A's New 2x3 Bench Top CNC-img_8023-jpg
  3. #687
    Oct 2009
    Front transparent screen in place.
    Blue crosses are taped to the screen:
    David A's New 2x3 Bench Top CNC-img_8028-jpg
    David A's New 2x3 Bench Top CNC-img_8026-jpg
  4. #688
    Oct 2009
    Email from Teknic:
    Hi David,
    Thanks for the information. The voltages that you're reading should be sufficient for accurate functionality with the HLFB and your controller.
    I would recommend next to test if the controller is correctly reading the HLFB change for this 1 axis.
    Once this is completed, repeat this entire test with 2 motors HLFB wired up
    (Measure the voltage between the two "measurement points" and verify that the controller is accurately functioning).
    After we get 2 motors working, lets move up to 3.
    Technical theory and our approach:
    In reviewing the C11G breakout, there is a possibility that the resistor alone may not be appropriate for a 4 HLFB system; the current drop between each servo may significant enough where the HLFB is not triggered. We expect to see a higher disabled voltage as the number of motors increase. (For example, the voltage may be 0.4 Volts instead of 0.197 Volts for a 2 motor system).
    The good news is that we may be able to use a different resistor or a 2nd resistor in parallel. Increasing the number of motors one at a time will help to give us a better understanding of the behavior of the circuit for recommendations moving forward.
    Best,
  5. #689
    Sep 2005
    So in other words, they don't know anymore than you do on how to make it work?
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  6. #690
    Oct 2009
    Quote Originally Posted by wmgeorge View Post
    Probably more like: So in other words, they don't know anymore than we guys do on how to make it work.
  7. #691
    Oct 2009
    A short video on spoil board surfacing:
  8. #692
    Oct 2009
    The dust hose elbow following the spindle:
  9. #693
    Oct 2009
    I ran the dust shoe base without the brush. Just the
    two suction pipes coming down to the dust shoe base.
    Although it doesn't suck up any particles from the bottom at
    that distance, the pipes do suck up quite a bit of floating dust.
    Look closely at the pipe ends:
  10. #694
    Oct 2009
    View from a seated position in front of the laptop:
  11. #695
    Oct 2009
    Most of the dust and particles are
    contained on the bed behind the screen:
    David A's New 2x3 Bench Top CNC-img_8048-jpg
    Some, mostly larger particles on the laptop, not much dust I could see:
    David A's New 2x3 Bench Top CNC-img_8043-jpg
    Or around the machine:
    David A's New 2x3 Bench Top CNC-img_8047-jpg
  12. #696
    Sep 2005
    Quote Originally Posted by davida1234 View Post
    Yes, thats it. And they designed the product.
