David A's New 2x3 Bench Top CNC - Page 40
Page 40 of 41 FirstFirst ... 303738394041 LastLast
Results 469 to 480 of 487
Thread: David A's New 2x3 Bench Top CNC
  1. #469
    Oct 2009
    Default Re: David A's New 2x3 Bench Top CNC
    Finishing up the mechanical portion of the machine.
    Now to VFD.........
    I showed an image of HY electrical
    connections I found online and the
    discussion about it somehow got lost.
    I cleaned it up a bit. Is this correct?
    David A's New 2x3 Bench Top CNC-hy-connection-jpg
  2. #470
    Oct 2009
    Also, the VFD is turned on together
    with the PS through a 30A relay.
    Is that OK as well or does it need
    its own on/off switch?
    Thank you.
  3. #471
    Mar 2003
    Shelby Township
    Yes, wiring is correct.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  4. #472
    Oct 2009
    Thank you Gerry.
  5. #473
    Jan 2005
    Quote Originally Posted by davida1234 View Post
    Thank you.
    The VFD and the Power supply need a correct sized Breaker that can be used as a switch as well, ( note not all Breakers can be used as a switch )
    The normal for U V W for it to turn the correct rotation is
    Pin1=U
    Pin2=V
    Pin3=W
    Ground Pin=4 (Check Pin 4 in your spindle to make sure it has continuity to the Spindle Body ) if it does not this has to be corrected and connected in side the top cap
    This type of Breaker is Ideal, there are other manufactures that have quality Breakers
    Attached Thumbnails Attached Thumbnails David A's New 2x3 Bench Top CNC-fuji-jpg   David A's New 2x3 Bench Top CNC-abb-jpg
    Mactec54
  6. #474
    Oct 2009
    Great, thank you Mactec54.
  7. #475
    Oct 2009
    I had published images of the terminals of
    VFD and Mactec54 had mentioned that it
    looks like the VFD is an older model HY.
    I can't find the original images now but they
    are towards the middle of page 18.
    I would appreciate if Mactec54 or somebody
    else has the settings for this model HY.
    Here are lower resolution images of those:
    David A's New 2x3 Bench Top CNC-img_7694-jpg
    David A's New 2x3 Bench Top CNC-img_7696-jpg
    David A's New 2x3 Bench Top CNC-img_7698-jpg
  8. #476
    Jan 2005
    You will need to cover the white wire if that is being used as a Hot, if not you should not have a Neutral wire in the mix for 240v single Phase supply
    When you Power it up and look at the Parameters what are the first 2 letters being used PD is the norm for HY VFD but it could be something else if your VFD is a copy
    What Spindle do you have
    Volts=220
    Amp=
    Hz=
    RPM=
    Poles=2
    Mactec54
  9. #477
    Oct 2009
    That wire is not connected to anything. Removed it.
    Here is what shows up in sequence when powered up:
    David A's New 2x3 Bench Top CNC-img_7889-jpg
    David A's New 2x3 Bench Top CNC-img_7890-jpg
    David A's New 2x3 Bench Top CNC-img_7891-jpg
    Volts=220
    Amp=
    Hz=
    RPM=
    Poles=2
    Here are the specs from their website:
    Technical Parameter of 2.2KW Water-cooled Spindle motor
    Spec:80*215mm(Middle body Diameter 80*215mm)
    Power:2.2KW
    Voltage:220V
    Frequency:0-400HZ
    Speed:0-24000RPM
    ER20 collet chuck water-cooled
    Runout off:Less than 0.005mm
    Grease Lubrication
  10. #478
    Jan 2005
    Power:2.2KW
    Voltage:220V
    Frequency:0-400HZ
    Speed:0-24000RPM
    Grease Lubrication[/COLOR][/I]
    Ok to find what your Parameters are press the Stop/Reset after it has finished powering up, then press the program Key and then enter and you will see what the Parameters letters are the Real HY start with PD for this model VFD
    Mactec54
  11. #479
    Oct 2009
    It is PD:
    David A's New 2x3 Bench Top CNC-img_7894-jpg
  12. #480
    Jan 2005
    It is PD:
    Ok that's good it is a HY here are the Parameter's for you, you now know how to set them also you just use the arrow keys to get to the Parameter number, this should get you going
    Huanyang Mactec54
    2.2Kw 220v 400Hz Water Cooled
    PD000=0 ( 0 For Parameter unlock ) ( 1 For Locked )
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
    PD003=400
    PD004=400
    PD005=400
    PD006=200
    PD007=20
    PD008=220 (Motor Rated Voltage )
    PD009=110
    PD010=11
    PD011=120 ( 100 Minimum Setting )
    PD13= 08 (is for Factory reset, Only use this to set VFD to Factory Default Settings )
    PD014=8 ( Acceleration Adjust to suit)
    PD015=8 ( Deceleration Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD023=0 ( Forward Run Only )
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD120=120 ( Stall Prevention )
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) 3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum RPM Setting )
    PD174= ??? ( To Be Set to the VFD Drives Max Rated Output Amps )
    Mactec54
