David A's New 2x3 Bench Top CNC - Page 36
Page 36 of 42 FirstFirst ... 2633343536373839 ... LastLast
Results 421 to 432 of 493
Thread: David A's New 2x3 Bench Top CNC
  1. #421
    Oct 2009
    Default Re: David A's New 2x3 Bench Top CNC
    Quote Originally Posted by OlfCNC View Post
    I have no idea why your axis not running. I have no experience with those servos unfortunately.
    Hi OlfCNC, appreciate the hotkey guidance.
    When I click on one of the jog buttons on the screen, the page behind it changes color, turning gray.
    Don't know if that means something.
  2. #422
    Oct 2009
    Quote Originally Posted by peteeng View Post
    To get around this adhesives are now used in joints to improve the connection grip vs friction eg loctite or epoxy.
    Hey Peter. I think adhesives is a great idea, thank you. Particularly considering that the finish on my parts is certainly nowhere even close to the level of perfection that you are used to.
  3. #423
    Jan 2005
    Quote Originally Posted by davida1234 View Post
    I NEED HELP!
    All axes individually work fine when connected to
    ClearPath software but nothing moves with UCCNC.
    Have been combing through the manuals for
    CNC4PC's C11G BoB, UCCNC and UC100 all weekend.
    UC100 and C11G powered on.:
    Attachment 416000
    Check that you are in the right mode in the ClearPath software Position mode
    Check that you don't have the override checked in there software, this needs to be unchecked
    The motors should be locked when you power up if not they are not getting the signal / power to turn on
    You can check the output of the Breakout Board with a meter to see if you are outputting a signal when you make a move or jog an axes
    Mactec54
  4. #424
    Sep 2005
    You know it all works because you ran with the Clearpath software. Its just getting the UCCNC controller to output the step and direction commands correctly. Its got to be something simple. In Mach3/4 the configuration of the Ports and Pins is very important to get right, what you need is someone else's set up file to look at, because those should be more or less standard. Getting the steps right is more of calibration process. You just need to see it run.
    BTW I purchased a low cost, about $120 or less hand held oscilloscope. I had to relearn how to use it from maybe 40 years ago but it really helped a lot.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4
  5. #425
    Oct 2009
    Thanks Mactec54, will do.
    I am confused. Is the ClearPath software still active when I run UCCNC?
    I thought you run the ClearPath software just to create a motor profile?
  6. #426
    Oct 2009
    Thank you wmgeorge, I hope it is something simple; just a 'duh' thing.
  7. #427
    Oct 2009
    Override in ClearPath software is OFF:
    David A's New 2x3 Bench Top CNC-img_7803-jpg
    The motors are locked up.
  8. #428
    Jan 2005
    That's good looking at what you just posted they are off as well so that part should be all good
    The Breakout Board has red lights they need to be green for operational
    Do you have the 5v board power correctly connected
    Do you have the EStop connected
    Mactec54
  9. #429
    Oct 2009
    There was one trace wrong on the wing
    pcb boards. Made a new board.
    The machine is jogging!
    Also, the inside adjustment screws for
    the nut retainer were difficult to adjust:
    David A's New 2x3 Bench Top CNC-47-img_7522-jpg
    I will be cutting new revised mounting
    plates and ball nut retainers for the machine.
    Should be ready in a few days.
  10. #430
    Oct 2004
    Thanks for posting. I was missing my David A's thread fix.
  11. #431
    Oct 2009
    You're too kind...
  12. #432
    May 2018
    Quote Originally Posted by Arjay View Post
    Me too. Can't wait to see a final product!!
