David A's New 2x3 Bench Top CNC - Page 3
Page 3 of 43 FirstFirst 12345613 ... LastLast
Results 25 to 36 of 505
Thread: David A's New 2x3 Bench Top CNC
  1. #25
    Oct 2009
    Default Re: David A's New 2x3 Bench Top CNC
    The four spindle mount frames are loosely assembled and each of the two SS shafts is attached to the spindle mount with four 1/4 screws.
    That's how it looks from the front:
    David A's New 2x3 Bench Top CNC-img_6-6313-jpg
    And from the back:
    David A's New 2x3 Bench Top CNC-img_7-6314-jpg
    You can utilize any parts of the design for your personal use.
    Please contact me for commercial applications.
  2. #26
    Oct 2009
    The completed Z-axis/slide/extension plate/spindle mount:
    David A's New 2x3 Bench Top CNC-img_8-6312-jpg
  3. #27
    Oct 2009
    With the Z-axis assembled, I'm moving on to the spindle.
    SPINDLE CONNECTIONS
    Electrical wire (IGUS) uses the spindle's original connector.
    I found a fitting rubber booth on Amazon that fits over it and protects it bit more:
    David A's New 2x3 Bench Top CNC-img_9-6075-jpg
    I am using McMaster Carr's 1/4ID-3/8OD PVC hose for cooling.
    I found it to be better than the one I got from HD.
    More pliable yet somewhat keeping its shape better.
    It will fit into the inlet/outlet clamp with some persuasion:
    David A's New 2x3 Bench Top CNC-img_10-6077-jpg
    Then the flow indicator is installed on one of the tubing:
    David A's New 2x3 Bench Top CNC-img_11-6078-jpg
  4. #28
    Oct 2009
    Cut the ends of tubing flush with the clamp:
    David A's New 2x3 Bench Top CNC-img_12-6079-jpg
    And attach the tubes to the spindle:
    David A's New 2x3 Bench Top CNC-img_13-6081-jpg
    Orient the flow indicator flat with the front of spindle:
    David A's New 2x3 Bench Top CNC-img_14-6080-jpg
    Install the electrical connector. Slip on the rubber booth:
    David A's New 2x3 Bench Top CNC-img_15-6082-jpg
  5. #29
    Oct 2009
    Spindle is ready to be installed into the Z-axis assembly.
    Position the bottom of the SS body about 1/8" below the bottom of the mount.
    Make sure that the inlet/out side of the spindle is inline with the front of the mount:
    David A's New 2x3 Bench Top CNC-img_16-6322-jpg
    Tighten down the clamp screws, four of them:
    David A's New 2x3 Bench Top CNC-img_17-6384-jpg
  6. #30
    Oct 2009
    On the back of the mount, there are two interior passages for tubing. Push a 1/4-3/8 tubing through that:
    David A's New 2x3 Bench Top CNC-img_18-6326-jpg
    Bottom view of the mount:
    David A's New 2x3 Bench Top CNC-img_19-6323-jpg
    Cut the end of tubing square. Heat up tubing and squeeze the tubing into
    the threaded cup end of the 1/4" LocLine hose:
    David A's New 2x3 Bench Top CNC-img_20-6327-jpg
    Push the tubing/LocLine assembly back up the channel:
    David A's New 2x3 Bench Top CNC-img_21-6328-jpg
  7. #31
    Oct 2009
    The bottom of the mount channel has a 1/4" pipe thread on it.
    Screw on the LocLine into it:
    David A's New 2x3 Bench Top CNC-img_22-6329-jpg
    LocLine installed on one channel:
    David A's New 2x3 Bench Top CNC-img_23-6332-jpg
    Spindle mount has two channels for LocLine installation in the back.
    You can use any of them for air or coolant and you can add them at a later time if you wish.
    I will be using just one at this time:
    David A's New 2x3 Bench Top CNC-img_24-6333-jpg
    The Z-axis / spindle assembly is finished and ready to be installed onto the X-carriage.
  8. #32
    Oct 2009
    I don't remember anymore how many times I changed the design, recut the parts and modified the details.
    This is a prototype test mule which can and hopefully will be changed to improve many more times.
    Any comments, suggestions or critique is very welcome.
  9. #33
    Oct 2009
    Moving on to the X-Carriage.
    X-CARRIAGE ASSEMBLY:
    All parts for the X-Carriage:
    David A's New 2x3 Bench Top CNC-a1-img_6436-jpg
    David A's New 2x3 Bench Top CNC-a2-img_6436-jpg
  10. #34
    Oct 2009
    I will start the assembly with the lower plate:
    Pillow block pairs consist of a top and a bottom part.
    Align and slide a ball bushing into the bottom part of the pillow block:
    David A's New 2x3 Bench Top CNC-a3-img_6445-jpg
    Then place the bushing and the block through the opening of the lower plate:
    David A's New 2x3 Bench Top CNC-a4-img_6446-jpg
    And slide the top part of the pillow block onto the bushing:
    David A's New 2x3 Bench Top CNC-a5-img_6448-jpg
    One ball bushing and pillow block set placed:
    David A's New 2x3 Bench Top CNC-a6-img_6449-jpg
  11. #35
    Oct 2009
    Install the other ball bushing and pillow block set.
    That's it for the lower plate assembly:
    David A's New 2x3 Bench Top CNC-a7-img_6451-jpg
  12. #36
    Oct 2009
    Preparation of the upper plate:
    Top view of the upper plate with elongated holes for tramming:
    David A's New 2x3 Bench Top CNC-a9-img_7366-jpg
    And the bottom of the upper plate:
    David A's New 2x3 Bench Top CNC-a10-img_7364-jpg
    Install shoulder screw:
    David A's New 2x3 Bench Top CNC-a11-img_7368-jpg
    And the 37MM angular ball bearing:
    David A's New 2x3 Bench Top CNC-a12-img_7369-jpg
