David A's New 2x3 Bench Top CNC - Page 2
Page 2 of 43 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 505
Thread: David A's New 2x3 Bench Top CNC
  1. #13
    Oct 2009
    Default Re: David A's New 2x3 Bench Top CNC
    Gantry Beam and Y/A Carriages:
    3060 gantry beam:
    David A's New 2x3 Bench Top CNC-img_7-6612-jpg
    Install 20mm linear rails top and bottom and then the Y/A carriages to the bottom:
    David A's New 2x3 Bench Top CNC-img_8-6676-jpg
    Turn gantry around and place it onto the linear cartridges:
    David A's New 2x3 Bench Top CNC-img_9-6692-jpg
    Attach the carriages onto linear rail:
    David A's New 2x3 Bench Top CNC-img_10-6691-jpg
  2. #14
    Oct 2009
    Machine frame with the gantry:
    David A's New 2x3 Bench Top CNC-img_11-6688-jpg
    Install big braces to gantry beam and the Y/A carriages:
    David A's New 2x3 Bench Top CNC-img_13-6736-jpg
    David A's New 2x3 Bench Top CNC-img_14-6737-jpg
  3. #15
    Oct 2009
    Install end caps:
    David A's New 2x3 Bench Top CNC-img_15-6666-jpg
    David A's New 2x3 Bench Top CNC-img_18-6769-jpg
    David A's New 2x3 Bench Top CNC-img_17-6766-jpg
  4. #16
    Oct 2009
    To finish the assembly of the main frame, plastic trim needs to be installed as shown:
    David A's New 2x3 Bench Top CNC-img_1-7082-jpg
    Same as with other plastic parts, use open gear grease on mating surfaces:
    David A's New 2x3 Bench Top CNC-img_3-6654-jpg
    David A's New 2x3 Bench Top CNC-img_4-6656-jpg
    Basic assembly of machine frame is finished:
    David A's New 2x3 Bench Top CNC-img_6-7082-jpg
  5. #17
    Oct 2009
    Btw, how do you make the posted pictures show up larger? They all end up posted as smallish thumbnails but are at the 1025 pix and 500kB limit?
    I tried it both as attachment and as image but no difference. Thanks.
  6. #18
    Oct 2009
    test...
  7. #19
    Oct 2009
    test 2
    sorry.......still trying to figure out how to upload a full size image and not a thumbnail
  8. #20
    Oct 2004
    Nice work.
  9. #21
    Oct 2009
    Thanks Arjay
  10. #22
    Oct 2009
    Main machine frame is finished. Time to move on to the Z-axis.
    Z-AXIS ASSEMBLY:
    Please note that some of the details are from earlier iterations.
    The design and concept is the same.
    It is easiest to assemble the Z-axis separately. These are the components for the Z-axis:
    David A's New 2x3 Bench Top CNC-img_1-6107-jpg
    The two linear shafts:
    David A's New 2x3 Bench Top CNC-img_2-6109-jpg
    You can utilize any parts of the design for your personal use.
    Please contact me if you are interested for commercial application.
  11. #23
    Oct 2009
    Place the square nuts into the slots of the spindle mount frames:
    David A's New 2x3 Bench Top CNC-img_3-6111-jpg
    Nuts installed and mount frames aligned. Middle nut acts only as a spacer:
    David A's New 2x3 Bench Top CNC-img_4-6112-jpg
  12. #24
    Oct 2009
    The four spindle frames with the nuts are stacked and ready for loose assembly:
    David A's New 2x3 Bench Top CNC-img_5-6108-jpg
