What should i purchase?
Results 1 to 3 of 3
Thread: What should i purchase?
    *Registered User*
    Jan 2019
    Default What should i purchase?
    hello all, im located in canada. my small business includes cutting aluminum composite 3mm 4x8 sheets. i cut approx 500 sheets a year. looking to purchase my own 4x8 router. it will be in my garage or basement. I am seeking some advice as to what type of machine to purchase. i have researched the cncrouterparts.com kits and like those as i can assemble it in my basement or garage. my only concern is do i need a really heavy duty industrial type setup for my needs (ie with a spindle, ball screws or rack etc). i only cut acm panels, and use 2 different bits currently. issues my current cutter guy has is hold down when cutting smaller parts as they tend shift sometimes. so i no for sure i would need a vaccum for the machine. i am able to assemble a kit myself, i just dont want to build a table for it i rather buy a full kit with everything i need and assemble it. i have software and computer so i wouldnt need that. concerning budget, i would pay 10k or less Canadian dollars if the machine can cut it properly. i have seen used industrial machines for sale locally for 10k-20k that look like they can do the job. links to kits that would work for based on what i cut now would be a big help. dont want to buy something overkill for my needs. thank you for your time
    -Age
    Mar 2003
    Default Re: What should i purchase?
    I would say the minimum you would want would be a CNC Router Parts Pro series 4x8. Complete, they are probably over $10K US.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    May 2005
    What are those usd machines like?
    Since you have a very specific focus here with those ACM panels you should have a good idea what the accuracy and cut quality requirements are. You already know the machines size (work space) requirements so you need to focus on how robust a machine needs to be to meet quality requirements. Since I know zip about ACM panels I can’t help much here.
