Need Help! Very rough surface finishing recently with c-beam build
Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Very rough surface finishing recently with c-beam build
    Activation process user834342's Avatar
    Jul 2018
    Question Very rough surface finishing recently with c-beam build
    Hi!
    I have a C-Beam based DIY CNC machine and when cutting my last piece the edges or surfaces are very bad. I've have some good results in the past but now not so much. I'm kinda a new to all this so not really sure where to look first in order to solve this.
    I've attached 2 photos showing the material and the chips.
    Controller: Arduino Due and g2core
    Spindle: Makita 700c
    Software: Fusion 360
    Is my tool blunt?
    Backlash?
    Bad choice of Fusion 360 operation?
    Too high feed rate?
    Any input much appreciated!
    Attached Thumbnails Attached Thumbnails Very rough surface finishing recently with c-beam build-20181206_182015-jpg   Very rough surface finishing recently with c-beam build-20181206_181952-jpg
    Jul 2013
    Default Re: Very rough surface finishing recently with c-beam build
    Quote Originally Posted by user834342 View Post
    Hi!
    Is my tool blunt?
    Backlash?
    Too high feed rate?
    I’m thinking:
    Dull tool ( get new tool)
    Too aggressive of a plunge cut ( take smaller steps down)
    Dry Cut (maybe add lubricant to smooth cut)
    Jul 2018
    OK so it's not something obvious then!?
    Jul 2018
    I had the same problem with a brand new tool so thought it wasn't really the tool.
    Here's an example:
    Very rough surface finishing recently with c-beam build-img_20180704_131813-jpg
    I also tried a really slow feed/plunge rate.
    Attached Thumbnails Attached Thumbnails Very rough surface finishing recently with c-beam build-img_20180704_131813-jpg
    Jul 2013
    Here's an example:
    Maybe use a Down Cut bit
    Jul 2013
    Quote Originally Posted by robwiacek View Post
    I. Any see how many down passes you use.
    If you are cutting 3/16 material..... do 5 light passes.
  7. #7
    Jan 2005
    I don't know about that it looks like the build has lots of problems, what are you using for a spindle
    Post a photo of the whole machine it looks like you have a rigidity problem plus not using some type of coolant, not all machine builds like this can cut aluminum
    Mactec54
  8. #8
    Jul 2013
    I agree... there’s a lot of chatter.
    But slow down the feed and plunge rates and add a coolant or at least WD-40
  9. #9
    Jul 2013
    Yeah but it looks like you should choose a down spiral bit
  10. #10
    Jan 2005
    It would not matter what kind of cutter he used if everything is vibrating and jumping around
    Mactec54
  11. #11
    Jul 2013
    That has a lot to do with it.
    But the consistency in the burr around the top of the cut shows it’s making an even pass with material being pulled out.
  12. #12
    Jan 2005
    What kind of cutter would you use on a machining center to cut aluminum, the same as what he is using, it's all about the machine and coolant, it looks like his cutter is HSS which destroyed it's self in the first 10 seconds of cutting
    The Endmill is out of the collet to far, by what is showing in the photo, if he is using a trim router or similar the bearings and router are not designed to cut aluminum, so you can't expect it to be great, but should be better than this if setup right and the machine is rigid enough
    Mactec54
