Techniques for piping vac hold on moving table?
Results 1 to 7 of 7
Thread: Techniques for piping vac hold on moving table?
    Jan 2011
    Default Techniques for piping vac hold on moving table?
    I've not been able to find any photos, videos or descriptions of how the big commercial machines work in this regard. So, I'll ask... How do they pipe the vacuum hold down with a moving table?
    Registered CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Techniques for piping vac hold on moving table?
    Most "big commercial machines" don't have moving tables to start with. Some machines (such as SCM wood routers) have movable traverse members with vacuum pods. They are connected to the pump with flexible vacuum hoses.
    Jan 2011
    Sure, "Big" is relative. But I consider this to be a pretty sizable machine.
    Is it using flexible vacuum hoses? Where would I find appropriate hoses?
    Mar 2003
    Something like this maybe?
    https://www.mcmaster.com/9118t6
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jan 2011
    Gerry that does look like it could work. But not cheap. And something tells me it's difficult to cut.
    I wonder about this Flexicraft hose: https://www.hosecraftusa.com/model/R...r_Suction_Hose
    Much cheaper per foot but $150 minimum order. And of course, cheap is relative as well.
    Aug 2005
    Another option from McMaster Carr;
    https://www.mcmaster.com/5393k49
    Fairly flexible and durable. Depending on your set-up, you may get away with a smaller diameter (pods/pucks, etc.).
  7. #7
    Gold Member
    May 2005
    Quote Originally Posted by chmedly View Post
    It is good stuff. You need a hose with internal or molded steel n support to keep it from collapsing.
    So? That is kinda the point you want a tough hose for this application.
    Not something I would consider.
    Yes cheap is relative. I do lots of work on high vacuum processing equipment where we sometimes use flexible stainless steel tubing between parts of the machines. Combined with the hard piping and this hose looks to be very cheap.
    In places where we can get away with cheaper solutions we use hoses very similar to the one Gerry pointed out. In some cases they have a plastic wire instead of metal. For hard pipe we will use copper pipe. Copper can be much cheaper than the stainless with their carefully welded flange fittings, clamps, gaskets and what not.
    If the pipe/hose is an issue you could always mount the vacuum pumps to the table. Sounds radical but could easily be designed in. It replaces hard to plumb large vacuum hoses with easy to drag chain electrical cables. You might even be able to reduce in table plumbing for zone support. The reality is that one or more large vacuum hoses would be a huge nussance on a moving table design. This is likely why few moving table machines have vacuum hold downs. Those vacuum hoses don’t last forever in static installations much less constant motion uses.
    Another option might be to plumb plant Air to the table and then use vacuum generators to do the hold down. Ultimately which method will work for you depends upon what you are doing. Vacuum generators are often used for light machining on milling machines.
