Newbie 3.5 Spindle wire
Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: 3.5 Spindle wire
    Jun 2010
    Default 3.5 Spindle wire
    What is the recommended shielded wire from the VFD to the spindle if I have a 3.5kw 220v? I think its 15amp?
    I cant find sh@t on 3.5 spindle wiring.
    Thank you
    Jason
    Mar 2003
    Shelby Township
    Default Re: 3.5 Spindle wire
    McMaster Carr 7777T21
    Igus CF31
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Mar 2010
    I just bought some Igus CF6 14-4 for my new spidle, 20ft. ran me about $80 delivered.
    https://www.igus.com/product/950
    Adam,
    G540, Rack and Pinion Drives-X/Y axis, 1/2-Ball Screw-Z Axis w/THK HSR 25 Linear Slides, Steppers KL23H2100-35-4B, Power Supply-KL-600-48
    May 2005
    Depending upon power factor and just looking at input power to the motor, current could easily range from 9 to12 amps. Plus we don’t know if the motor is rated for output power and thus the possibility of efficiency being a factor.
    In any event the NEC requires all electrical motors to be rated with all the data you need. In this case you need the phase current value. It is likely well under 12 amps so 14 gage wire would do. If the current rating approaches 14 amp I’d upgrade to a 12 gage cable. A decent cable suitable for drag chain usage is a bit expensive but worth every penny.
    By the way this assumes running a 3 phase cable to the motor from the VFD. A single phase run requires a 12 gage cable.
    Jun 2010
    Single phase
    Jun 2010
    Perfect, went with 12g.
    Thank you
  7. #7
    May 2005
    A VFD implies 3 phase wire to the motor.
  8. #8
    Jun 2010
    This is the model I have.
    DZB200B003.7L2A 220 3.7 220V 50/60Hz 0~200V
    0~600Hz 15
    Oops, read back a bit... Got ya
  9. #9
    Jun 2010
    Hmm I already posted this but it didn't take.
    I need to figure out the VFD to spindle and to controller wiring.
    How do I check ohms on the spindle? Its has 1-4 and a grd.
    VFD to spindle from UVW?
    Controller to VFD RST?
    Control has a 3 pin out 1=24v, 2=gnd, 3=0-10v?
    Any insight would be great. I cant find the manuals for these anywhere.
    Thank you
    J
  10. #10
    Jan 2005
    Quote Originally Posted by wizard View Post
    You are getting a little carried away with your cable size, these quality cable that most are using 16gage is rated for 20Amps
    Mactec54
  11. #11
    Jan 2005
    Quote Originally Posted by JasC View Post
    Thank you
    No point in using 12gage if it won't fit in your plug post some photos of what your spindle or motor connection has, you can't just buy any sort of cable and expect it to work for you
    Mactec54
  12. #12
    Jun 2010
    Its is large and will fit I checked. Second its shielded for this type use.
    J
3.5 Spindle wire
3.5 Spindle wire
