New Machine Build harmonic gearhead rotary axis build
Results 1 to 8 of 8
Thread: harmonic gearhead rotary axis build
    Jun 2012
    Default harmonic gearhead rotary axis build
    hello forks,
    been a long time to be here.
    Today I finished building my new rotary axis so I am here to share the joy with you guyz
    build log part 1 (link corrected, sorry for the trouble)
    build log part 2
    Cheers,
    Kevin
    Feb 2017
    Finland
    Default Re: harmonic gearhead rotary axis build
    What gear drive is it?
    Jun 2012
    hollow-type harmonic series 20-50 series from HD systems in Japan.
    SHF or SHG but I failed to find exact matching model, measured all dimensions myself not to make wrong PCD holes.
    probably a custom-sized one, dissembled and sold by a scrap company, 48T S3M pulley already attached when it came to me.
    Kevin
    Sep 2005
    Indonesia
    I also interested in 4 axis rotary with harmonic drive. I found one just like what you describe. Is it the one you use :
    harmonic gearhead rotary axis build-bshf-14-cru14-70-cross-roller-bearing
    What size do you use ? How about the one below, it is easier to build with.
    harmonic gearhead rotary axis build-bcsf-40-bcsg-40-crb40-126-cross
    Jun 2012
    mine is from this company
    SHG Series Unit Type (Hollow structure unit, hollow structure lightweight unit) / HarmonicDrive® / Select by Product Category / Product Information / Harmonic Drive Systems Inc.
    and from the picture, I can only guess that chinese copy company even copied naming of each model.
    from the above link, you can look for model table, mine is series 20, with 50:1 reduction (which in fact 51 turns pere one turn of output)
    size 20 is good for 100mm chuck(4") with a backplate.
    cheers,
    Kevin
    Jun 2010
    Hi asuratman
    CAUTION: the photos you are showing seem to be for Crossed Roller bearings, NOT for a Harmonic Drive, despite the pictures.
    Cheers
    Roger
  7. #7
    Sep 2005
    Indonesia
    I do not know the different between them. Do those things can't be used for rotary table. I am interested due to price is cheap. I do not know what the meaning cross roller bearing for harmonic drive. Maybe we need those two.
  8. #8
    Jun 2010
    A crossed roller bearing (CRB) is the main support component for a harmonic drive (HD). You can buy just the key components of a HD if you want to integrate it into what you are building (eg a robot arm) with your own bearings, or you can buy a complete HD gearbox with the CRB integrated. Look up the engineering drawings for a complete gearbox on the HD web site.
    Cheers
    Roger
