Acceptable Runout for Hitachi Router
Results 1 to 5 of 5
Thread: Acceptable Runout for Hitachi Router
    Member Biggs427's Avatar
    Feb 2016
    Default Acceptable Runout for Hitachi Router
    I'm running an Hitachi M12VC on my router and I measured a 0.04mm (0.0016) runout in the taper where I put the collet.
    Since my bearing needed to be changed, I did changed it thinking that this might be the cause of the runout but it is the same after bearings change.
    As I'm mostly working with wood, 0.0016 isn't much but I'm wondering what problems I might run into with it.
    Jun 2005
    Default Re: Acceptable Runout for Hitachi Router
    That is common on a router. Even the Chinese Spindles have a run out around .001, but they can run all day long, so are more commercial than a Hitachi router. I used that same router for about 3 years, changed the bearings twice as it wear out due to the heavy use. In wood you will never notice that small amount of runout.
    Russ
    May 2005
    If you ever did have an issue with run out, say doing something it aluminum, you could always try a single flute cutter. In the end you will have probl me with wear if the rub out is close to your feed per tooth. You can end up with a significant nation where one edge of a multifoutecutter doesn’t cut at all.
    Feb 2016
    For alu, I'm using single flute most of the time so I should be ok.
    Thanks guys.
    May 2005
    Man I need to turn off iPhone auto correct.
    How it managed to change runout to rub out is beyond me.
    Quote Originally Posted by wizard View Post
