New Machine Build New 1200 mm linear rails
Results 1 to 6 of 6
Thread: New 1200 mm linear rails
    *Registered User* JammyJulien's Avatar
    Oct 2018
    Default New 1200 mm linear rails
    Hello All,
    I made a small CNC machine about a year ago - maximum cut area is 395 x 395 mm. Works great ! I've mounted a router, diode laser, and drag knife. Possible the best thing I've ever made. All controlled by an arduino with GRBL, which in turn is controlled by a Raspberry PI and bCNC.
    I was browsing Banggood the other day, and saw 51% off 1200mm linear rails, so I bought 4 with the intention of rebuilding for a bigger cutting area. I'd like to be able to made my own kitchen cupboard doors as a first project.
    Enough waffle - here's my question : My Y axis currently runs with one stepper motor, and a central lead screw controlling it. I'm wondering if the larger size may require two steppers and lead screws to prevent skewing ? If anyone thinks that would be the case - Is it possible to just add a new stepper driver just run the arduino signals in parallel ?
    Many thanks in advance
    Julien
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: New 1200 mm linear rails
    There's a good chance that it will.
    If the Arduino can supply enough power, then yes, that's one way to do it.
    UCCNC 2017 Screenset
    May 2005
    Quote Originally Posted by JammyJulien View Post
    Hello All,
    Julien
    Eventually a machine gets large enough to where dual leadscrews are the economical choice for router like precision. There are a number of factors that come into play though. One is the mechanical arrangement of parts. Moving table solution's can get by with one leadscrew far longer than a moving gantry machine.
    So ultimately your questions will be answered when you zero in on the machines design.
    Member Biggs427's Avatar
    Feb 2016
    I'm running two stepper with one drive each on my X axis (probably what you're calling y axis) to drive two ball screws.
    Both drives are linked to the same pin on the Arduino. I'm running this since 18 months and it has been running great.
    Two screws / motors would prevent the gantry from racking, especially with a ~1200mm gantry unless your axis is really beefed up!
    I found it more practical even economical to put two lead screws on my machine.
    Oct 2018
    Many thanks Biggs - I'll factor two into my design
    Yes...you can control two motors with one port from the Arduino. I'm assuming it's an Arduino Uno which is what I have. I have two motors on my Y Axis and I run the single Y out signal from the Uno into two discreet controllers. Provided the motors are the same and there are no issues with either controller, the motors stay synced. I sometimes run the Y axis up against a stop by hand (there's a stop on both sides of the gantry) and I turn on the controller box, then I'll move the gantry where I want it. That way the gantry is parallel with the X axis.
    Quote Originally Posted by ger21 View Post
