Need Help! Cnc Extra Cut Prolem
Results 1 to 4 of 4
Thread: Cnc Extra Cut Prolem
    Jan 2018
    Yemen
    Default Cnc Extra Cut Prolem
    Hi Guys
    I Have i problem with my cnc it's start to make
    an extra cut in every cut i make
    i tried to fix it but no luck so
    i need your help plaz to fix it
    Cnc Extra Cut Prolem-img_20181020_102214-jpg
    thanks ...
    Attached Thumbnails Attached Thumbnails Cnc Extra Cut Prolem-img_20181020_102214-jpg
    Jan 2007
    Default Re: Cnc Extra Cut Prolem
    Where is the top of the material? Look at the end of the G code file. I always edit my programs as I get several extra lines that my post processor adds in, especially a G28. The G28 will take it to the home position. Looking there may help you find the problem. Being able to read a code file by sight will put you way ahead of the curve. Try writing a simple path and see. Lots of fun.
    Jack
    Jan 2018
    Yemen
    hi jack
    thanks for your respond
    i tried to fix the G code but i had the same problem
    so today i cleaned the stepper moter and now it's work fine .
    thanks for your time man
    Mohsen
    Jan 2007
    AHA The old missing steps trick. I didn't think about that. I have a Bridgeport Boss 5 with NEMA 35 motors and don't have a missed step problem. Unless I try to move to fast.
