First off DIY routers are more hobby oriented than commercial solutions. I say more because there is certainly a number of builders here that in fact build for commercial uses. What that mix is I wouldn't want to guess.
If you are like most business owners the machine needs to pay for itself eventually or it just becomes a boat anchor. So you need a plan to use the machine and that paln would dictate what sort of machine to buy.
This doesn't sound like much of a plan to make a $10,000 machine pay for itself. Frankly routers don't make very good spindles so i'd put the router idea on the back burner.I am looking at the cnc router parts pro 5x10, nema 34 pnp system, artcam pro, and using a porter cable 7518 to get started. I would like the 3hp pnp spindle but thought the router would be good to start since this would not be cutting the bulk of my cabinet parts just some specialty parts and add some additional woodworking areas.
Technically you don't feed parts to the router you set them up on the router table. For sheet good processing that could mean clamping or screwing down the in such a way that the router avoids the clamping method.If it looks like im pushing the router to hard then ill buy the spindle and use the router in my shop somewhere else, but if it works fine then use the extra cash for additional software or a vacuum table. With the router I was looking at $11,000 for this setup.
Questions:
1.I use some older Cabnetware and Cabinet Vision, the cutlist files and some optimization. Once setup and I decide to move the process from my panel saw to this cnc(after adding a spindle) what would it take to feed the parts to this router?
While some will argue a router isn't always at it's best trying to replace a panel saw. You would need to review work flows carefully to best leverage a CNC router. Of course on a more sophisticate machine you can get saw blade heads for your spindle so the argument can go multiple ways. In a small shop though you can't count on your low end CNC router always being the best solution to break down sheet goods.
With the right machine, spindle, job and controls you might handle 20 in an hour. It is pretty hard to answer this question really, as it is very job related. One thing you run into with routers is that the cutter is going to be changed out far more than a 12 or 14 inch saw blade ever would be. Beyond that once you have automatic equipment the potential is there to automate even more of the process.2.If I did the above would this be able to handle say 20 sheets of 3/4" ply in a day?
In the end the job dictates run time. Thankfully modern CAM software will estimate cut times for you.
In the old days it was very easy for closed loop systems to go crazy. The trick with steppers is proper setup and leaving some margin so that the occasional rough spot doesn't stall the motors. As for crashes it really dones't matter if an open loop stepper system or a servo based system crashes, in either case you make a mess of things and have to start over.3.I have read of open loop machines losing steps and the cutting going crazy, is this a common thing with this level machine? Can it be prevented?
[quote]
4.If there are other brands you would recommend please point me there. I liked the price point and positive reviews of cnc router parts, but havent bought anything yet.
[/qoute]
For a business with a budget of $10'000 I'd most certainly would look on the used equipment market. Buy used buy more!!!! It is better if the used equipment you buy still has support from the manufacture, if not DIY controllers handling 3 axis are pretty easy.
Some of the low end kits amount to great rip offs if you want my opinion on that. They charge a lot of money for a few extrusions cut to length. So be careful when shopping in this market segment.
One thing to consider is that a large router in say your 10 x 5 size take sup a lot of room in the shop, plus it makes a lot of noise. Depending upon the design of the gantry you will need clearance all around the machine, especially on a 5 foot wide machine. This can mean at a minimal a space of 14 x 9 feet and that is tight, too tight really to handle full sheet goods. So from a shop layout perspective you may need to add an extension onto your shop just to accommodate a machine this size. Either that or a number of other machines get sold off.Thank you for your help. Wanted a cnc for to long to mess up when I finally get one.
