New Machine Build My second big 5 axis
Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: My second big 5 axis
    Feb 2010
    Poland
    Cool My second big 5 axis
    Hello.A long time I was not here. I got an interesting job to do. This 5 axis. Another company did not build the machine, I received several parts to build it.
    I have a planed beam and several supports. I drew a new project and started to build the machine.
    The assumptions:
    working area x3m, y8m, z2m, head BC, c 350, B +- 120,
    Drive with servomotors Delta B2, head with harmonic gear's, xyz planetary gear's. Axis X and Z ballscrew. Y tothed rack's.
    A few photos
    My second big 5 axis-5axis1-jpg
    My second big 5 axis-5axis2-jpg
    My second big 5 axis-5axis3-jpg
    My second big 5 axis-5axis4-jpg
    My second big 5 axis-5axis5-jpg
    Jan 2008
    Default Re: My second big 5 axis
    Good to see you back Bartuss.
    I like the cnc cut plate weldment
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
    Feb 2010
    Poland
    today I welded one side, tomorrow the other, and then all angles will be set
    My second big 5 axis-5axis6-jpg
    Feb 2010
    Poland
    All angles are, diagonals also after welding side's. I started to paint it
    My second big 5 axis-5axis7-jpg
    My second big 5 axis-5axis8-jpg
    My second big 5 axis-5axis9-jpg
    My second big 5 axis-5axis10-jpg
    Feb 2010
    Poland
    Today I drew the Z axis. The drawing went to the laser.
    My second big 5 axis-z-axis-jpg
    Feb 2010
    Poland
    I welding the Z axis. I bought a harmonic gear for axis C to head.
    My second big 5 axis-5axis11-jpg
    My second big 5 axis-5axis12-jpg
    My second big 5 axis-5axis13-jpg
  7. #7
    Feb 2010
    Poland
    I have a guides Hiwin 30. Actually I turning shaft's for drive Y axis.
    My second big 5 axis-prowadnice-jpg
    My second big 5 axis-y-axis-shaft-jpg
  8. #8
    *Registered User*
    Jul 2018
    This is amazing! Whats the cost range of a build like this and capabilities?
    Whats this: "head BC, c 350, B +- 120,"
    I'm trying to build a 5-axis laser + cnc capable of working with 1/8" aluminum (cutting and welding) wiht work area of x1m x y1m 0.5mz + 360x' + 360 y'
    Looking forward to your build and learning a lot. Apologies if they are newbie questions, kindly point me to the relevant sticky or forum area.
  9. #9
    Mar 2013
    Wow! Excellent!
    Sent from my iPhone using Tapatalk Pro
  10. #10
    Feb 2010
    Poland
    Head BC have an angle axes for spindle position, C axis 350 deg around Z axis, B axis +- 120deg around Y axis.
    My previous 5 axis machine :
    Cost about 60 th dollars
  11. #11
    Mar 2013
    What do you make with the machines?
  12. #12
    Feb 2010
    Poland
    I make this to order
