You'll probably need to go to using 2 ports with 2 breakout boards. A parallel port only has so many IO's.. 12 out and 5 in normally.
What are you using for a control? Mach 3?
The single parallel port USB controllers will probably have issues trying to use more than one in the same system. You'll probably want to go with a Pokeys or smoothstepper interface which has more I/O points from a single USB/Ethernet connector.
