Probably the biggest tip i can give is try to come up with the most rigid deign possible that fits the budget and tools available. It is fair to say that this is always a struggle.
The feasibility of doing so depends upon the machines size and what you can get suitable materials for. In the end only you know local conditions as far as buying materials and services.I wanted to design a machine that is suitable for wood. If it can cut aluminium at slow speeds then that will be nice too, but it is not the aim. I don’t have a clear budget, but my aim is to stay under 1000€ and have nice rigid machine.
Flat parts are of limited usefulness in my opinion.At my work they have a lasercutter so i can ask them to lasercut a few things for me for free (only flat parts and not on a regular basis).
It might be a good idea to define standard tools! That is for both you and the guys reading the thread. Often it makes sense to take an inventory of your tools to see if you will come up short anywhere.I regularly model in unigraphics so i have acces to that as well. I also got 5 NEMA34 motors (PK299DW-A4) and 1 driver (RBD245A-V) from an abandonned project. Other than that i just have standard tools.
Any suitably rigid machine, even one made out of wood, will be heavy. A tip up machine will require some engineering thinking to assure safety. Totally doable but you need to make sure falling on somebodies head is impossible and you need to make tip up safe for your back. The other thing here is that the more rigid your machine the least likely you will have alignment problems setting it up.Please see the attached images of my first design draft and my partslist with prices from the websites where i want to order it. I made the following design decisions:
- The machine has to fit in a small shed so i tried to keep it a bit compact. I plan to rotate the machine in a vertical position when it is not in use (still have to add this to the design).
Machine size can make or break a budget. If the budget is tight then keep the machine small and rigid.- I aimed at a 1000x70x10cm usable workarea (doesn’t have to be exact)
Unfortunately unless you have access to a metal break to bend those flat pieces into usable assemblies i dont see a lot of uses for flat stock.- I tried to keep all lasercut parts the same thickness (3mm) to keep it simple and easy to lasercut.
Distortion can come from a number of realities in metal working even laser cut sheet stock can deform. Dont be surprised if you laser cut stock requires some wrangling to go to gether as designed.- I don’t have easy acces to welding equipement so i created a design that is fully bolted (see detailed image for an example connection). This gives me the bonus that i can still take it apart if needed and there are no
deformations from welding so everything should fit and adjust nicely.
As for bolted up construction, nothing wrong with that. Do plan on gussets angle brackets and so forth.
If you are on a budget it is always smart to work with what you got. As for drivers and power supplies you need to know the electrical characteristics of the motor. Each model is a bit different and properly matched drivers and supplies makes a huge difference in performance.I still struggle with the following questions:
- Is it smart to use the NEMA 34 for x and y and what drivers should i use for it? I have enough steppermotors, but only one driver.
Off the top of my head no. Assuming your Z is the vertical axis, that axis is working against gravity. That could be an issue with a heavy Z axis.- I used a NEMA 23 for z although i still have more NEMA34s. I thought the whole thing would be too heavy with a NEMA 34 on the z. Is this the good decision?
That cant be answered without the motor specs. My gut feeling is that 12 VDC will be too little.- What power supply should i use? I can probably get a 12V 60amps power supply for free, but is this usable with these motors.
Im not familiar with that model. Generally on a low budget machine you implement something cheap until you can upgrade.- I chose to use a Makita RT0700C spindle? Would this spindle be proper fort his setup?
Sadly some of the cheap Chinese bearings are just that - cheap. On a cheap machine build you upgrade to higher performance stuff in the future.- Are there any parts that i am buying for too much money (see pricelist)? I can get the bearingblocks for my spindle a lot cheaper, but then the bearing block and spindle are from different suppliers. Is there a chance that this will
result in problems with tolerances?
The basic design bothers me. The basic table design looks like it would be almost as rigid as cookie baking sheet. That isnt good.- Any other design things i am doing wrong?
The gantry construction isnt clear to me (on my cell phone). However it looks to be thin. Especially on the gantry, you would be just as well off to use a steel box beam. While they would be different sizes id use steel box beams (square tubing) for a good part of the remainder of the machine. For the most part, a bolted together machine from steel tubing is faily easy to do.
At the moment im traveling so wont be looking at new files.If helpful i can also share the 3d files.
Thanks,
