It all starts with cutting the materials square! That requires a precisely set up saw of some type. Ive used a miter saw set up with a precision machinist square. I believe 8020 at one time used a table saw with a orecision cross cut sled.
In any event a square structure starts with cuts that are square on the ends. It is the critical first step.
As for things like gusset plates and tie plates they do nothing for squareness. Most of the plates are nothing more than bar stock or sheet goods with some holes drilled in them and as such do not index anything for alignment. Angle brackets can achieve some level of squareness but one alone they are not structurally sound.
Im on my cell at the moment so those part numbers mean nothing to me. However what stands out here is the machines size. You didnt mention that because 1530 may or maynot be suitable for a router or even a setup table. By the way setup table isnt defined either. So we can only talk about T Slot contruction in general terms. The first thing here is that every joint benefits from reinforcement usually in the form of angle brakets or gusset plates. The gusset plates can be supplied by the manufacture or you can make your own. Angle brackets are a bit harder to do on your own but not impossible.
One thing you might not be aware of is that you will be nickle and dimed to death for much of these ""accessories"". The T Slot nuts, bolts, brackets and so forth add up to alot of money if you do a solid build. Your mill and bandsaw has the potential to save you some money here if you want to spend the time doing brackets. In any event the cost of T Slits can be high compared to doing the same structure in steel (subject to change). As such i almost always suggest that people look at steel tubing for a machine frame. Steel might not work for a setup table though if those T Slots will be used for setting up whatever.
So we need more info here especially about this table size and what is being setup on it.
