Just a guess, but possibly noise from the VFD interfering with the electronics.
Since I got my spindle & vfd setup my router hasn't finished a job correctly. I sent a job with 5 cuts & after the first 3 went fine the 4th one started cutting diagonally across the board. I reset everything & tried again it did the same after the second shape. So I sent just the outside pocket cut it did the shape but didn't cut the whole way through the pvc the whole way around the shape. It kind of looks like it ramps out of the whole (part of it cuts through part of it doesnt).
I check all data cables & everything seems right. I also sent my g-code to a local machine shop & he said it looks correct without any issues
Any help is greatly appreciated
UCCNC 2017 Screenset
Ok I'll try moving the cables as far away as possible tomorrow. Is there a way to add a shield the cables at all? I remember years ago you could buy magnetic pieces that clipped around you computer power cables to help with interference.
There is shielded power cable available.
https://www.ebay.com/itm/25-FEET-Shi...UAAOSwcjhazQP4
I can't really think of a good way to shield the cable externally.
Also, installing a line reactor would help.
https://www.automationdirect.com/adc...actors/LR-22P0
Just clipping a ferrite around the cable won't do much.
Jim Dawson
Sandy, Oregon, USA
I used SO 16 gauge line, I thought that was what I should have used.
16 gauge is proabaly fine for your power requirement, I just grabbed the first example I saw off of ebay and it happened to be 12 gauge. SO cable will work, but it's not shielded. I have successfully used it between the VFD and the motor, but the separation between it and the control cables is on the order of several feet. In the case of my router, the VFD cable was strung about 4 feet over the top of the gantry on a track so it could move with the spindle motor and not run through the cable track. On my mill, the control cables are on the opposite side of the machine from the motor drive system.
Is everything properly grounded, back to a single point?
Jim Dawson
Sandy, Oregon, USA
My table is 4x8 so hanging the wire above isn't something I'd like to try I'd probably rather buy new shielded wire & rerun it.
Do I need to keep the 16 gauge vfd cable away from the wires going from the vfd to the control panel or the cables running from the control panel to the stepper motors or the serial cable (I know old machine) running from the computer to the control panel ?
My router was a 4x8 also, but it did have a fixed gantry with a moving table. I mounted the VFD on the outside of the control panel, but it was fed from the control panel. Also had a line reactor inside the panel, but the run was very short and the power wiring was on the opposite side of the panel from the control wiring.
The black transformer looking device on the lower right is the line reactor. The SO cable is connected to the line reactor the exits the cabinet on the right. A bit hard to see in the picture but it's the black, white, red wires connected to the line reactor.
The grounds are all brought back to a single point in the cabinet.
The cable track overhead
The bottom line is keep the VFD cables well away from all other wiring.
Jim Dawson
Sandy, Oregon, USA
What control system are you using?
DeskCNC
I'm pretty sure I got the issue figured out, at least I ran an "air" job that had issues before.
I'm not sure which wire it was but I had a few wires close together & I separated them. I had the 220 line that runs from the breaker box to the VFD touching the 3 following 3 wires SO wire that goes from the VFD to the spindle and the cat 5 wire I used to do from the VFD to the control panel, and the serial wire running from the computer to the control panel.
Gary
Yes you can shield the transmission wires using a stainless flexible 1/2 shower hose sir, I think it`s available at home depot or ace hardware in your area
Put all the wires inside then drill a hole on the connector and screw the ground wire and connect it to neutral on your outlet (earth) you now have an external ground shield on your wires
Which wires are you calling the "transmission wires"?
Usually the wires that requires shielding is the wires connecting the spindle itself going to the VFD module, input wires on the VFD are just wired the normal way. are you using UTP cable on your control wires sir?
Sorry I purchased the router used and I'm not sure what wires the original builder used. My table is 4'x8' and the cable running from my vfd ro my spindle is 32' long & the OD probably wouldnt fot in the 1/2" shower hose very easily & if it would I know it wouldnt fot inside the wire track and it would need to hang from the roof & that would require an even longer cable & somehow to let the cable reach all corners of the table without hanging & causing problems elsewhere.
Thank you
Gary
I think you can buy a shielded (braided) cord from your local electrical store that looks like this.
You need to shield the transmission wires from the VFD going to the spindle, usually electrical noise intensifies when the router experiences abrupt or heavy load / drag on it`s tool bit on the material you cut, if it`s shielded to ground / neutral even if you reach FLA (full load amperage) on your router motor it wont bother anymore on your breakout board electronics module causing offset / miss steps errors.
KH0UJ - you are correct one the router got under load it started loosing data.
So far I've contacted 2 local electrical supply shops, neither has anything as heavy as I need (14 gauge 4 conductor shielded wire) one said he had no idea where to find it and the other is making calls to his suppliers. One wire was found some but it has a semi-rigid pvc outer insulation and has what looks to be aluminum foil as the shield not the braided like the sample photo. This wont flex enough to run through the cable chain.
Does anyone know where I can find this wire?
Thank you
Where are you located?
Order direct from Igus, or 7777T21 from McMaster Carr, which I think is actually Igus cable.
