You need to realistically look at how thick you can actually cut? Unless you are cutting foam, it's difficult to cut 3D parts thicker than ~50mm on a 3 axis machine, due to tool length and clearance issues with the collet.
About 125mm clearance, and 200mm of Z travel should work well for both situations?
