Need Help! My router went today on my old DIY table need advise - Page 15
Page 15 of 15 FirstFirst ... 512131415
Results 169 to 174 of 174
Thread: My router went today on my old DIY table need advise
  1. #169
    Mar 2003
    Default Re: My router went today on my old DIY table need advise
    PD144 should be set to 3000.
    There's a jumper in the VFD that needs to be set to terminals 1-2 for external control. Make sure that it is.
    Do you have PD072 = 400?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #170
    Jun 2017
    Thanks I'll check Monday when I get back to the shop
  3. #171
    Jun 2017
    I wrote up a long post early this morning but I don't see it now.
    I checked pd 0072 and it was on 400.
    I changed pd 0144 to 3000
    I changed the jumper to 1-2
    It is working "occasionally" now through DeskCNC but I cannot figure out what I'm doing that makes the spindle to turn on. Impress run on the vfd the toggle the CCW ON / OFF a couple times & it will start up. I'm sure it is probably operator error but it would be nice to figure out the key to getting it to start consistently.
    The good news is I can adjust the RPMs but moving the spindle slider on DeskCNC, but the RPM's values on DeskCNC & the VFD don't match exactly.
  4. #172
    Jun 2017
    Anyone?
  5. #173
    Mar 2003
    You need to make sure that DeskCNC is outputting the proper voltage, and doing what it should be to start and stop the spindle.
    I've never used it, so can't really offer any help.
    Unfortunately, there probably are very few people using it. I thought they stopped selling it 10 years ago.
  6. #174
    Jun 2017
    Ok thanks I was afraid that was going to be the issue.
