Correct, but regardless, as the spindle goes up, so does the lower bearings, increasing the lever arm of the carriage, reducing the distance between bearing blocks (unless a taller gantry is made), and reducing the stiffness of the system overall. But I suppose it's po-tay-tow, po-tah-tow
