CNC router build - Page 28
Page 28 of 28 FirstFirst ... 1825262728
Results 325 to 331 of 331
Thread: CNC router build
  1. #325
    Mar 2010
    Default Re: CNC router build
    Looks good... I would just double up on the side plate below the gantry
    It must be nice to be able to scrap some 1" acrylic, lol!
    Adam,
    G540, Rack and Pinion Drives-X/Y axis, 1/2-Ball Screw-Z Axis w/THK HSR 25 Linear Slides, Steppers KL23H2100-35-4B, Power Supply-KL-600-48
  2. #326
    Jun 2017
    Quote Originally Posted by adam_m View Post
    Adam,
    Thanks for the advise....i will surely consider it. I had a piece of 12mm acrylic left over from a job i did for my wife so i glued pieces together to make 24mm thick pieces. Yes it's a shame to waste all that acrylic but my cad skills are poor so i have to rely on making and remaking parts at the moment. I am worried about the weight of the gantry though....it's going to be really heavy!! It moves easy and smooth but there is still a lot of weight to be added
  3. #327
    Mar 2013
    UK
    could you put some traingular corner brace pieces between the carriage plates and the gantry side arms? I imagine that would stiffen it up pretty well.
  4. #328
    Jun 2017
    Quote Originally Posted by zeeflyboy View Post
    I was thinking the same thing......hopefully there will be enough room for the z axis cause i would like to access the whole area from side to side on the machine base when milling. Most of it i tried to draw up but i usually mess up somewhere.
  5. #329
    Mar 2013
    UK
    well at the very least you can have a corner piece right up to the gantry bottom behind the Z-axis
    Looks like you could fit one or two nice 25mm thick brace pieces under the gantry beam without interfering with your ability to get the Z-axis to full travel.
  6. #330
    Jun 2017
    You are correct, there should be enough space.
  7. #331
    Jun 2017
    Yesterday i fitted part of the z-axis to confirm a few things....all goo. So today i started making the final ball screw bracket for the x-axis.
    CNC router build-bracket3-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-bracket3-jpg
CNC router build
CNC router build
