CNC router build - Page 25
Page 25 of 26 FirstFirst ... 152223242526 LastLast
Results 289 to 300 of 302
Thread: CNC router build
  1. #289
    Jun 2017
    Default Re: CNC router build
    Completed the psu/converter. Hope to test it next couple of days...
    Attached Thumbnails Attached Thumbnails CNC router build-pcb5-jpg
  2. #290
    Jun 2017
    Well i had a bit of trouble. The new 8pin micro i bought for this unit was not supported by any of my programmers. After struggling for a while i decided to order another part that my hardware supports. Hope to receive it soon....meantime i made a few changes to the pcb to be able to connect my programmer to the board. The lengths of the ball screws are almost finalized
  3. #291
    Jun 2017
    Update....i managed to sort an old pc to control the machine. Loaded and tested Mach3, all good. The little power supply/converter is now programmed with the correct 8 pin micro. Will test it soon
  4. #292
    Jun 2017
    Success....the little unit is working very well. I am getting a stable speed ref to the VFD. Everything is linear and spot-on, without tuning i managed to get 150.3 Hz when i selected half speed. Time now to complete the last bit of wiring and tidy up the panel.
    The only thing i didn't check is the power consumption on the 5V side....cause my psu can only supply a maximum of 1 Amp.
    CNC router build-test4-jpgCNC router build-test5-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-test4-jpg   CNC router build-test5-jpg
  5. #293
    Registered Biggs427's Avatar
    Feb 2016
    This is great!
    This enclosure is really neat!
  6. #294
    Sep 2005
    Indonesia
    Very nice control box, it looks like my fanuc.
  7. #295
    Jun 2017
    Quote Originally Posted by Biggs427 View Post
    This is great!
    Thank you...
    - - - Updated - - -
    Quote Originally Posted by asuratman View Post
    Thank you
  8. #296
    Jun 2017
    Finally completed the sizing of the ball screws, hopefully i did not stuff up the sizing. The ends have been machined and they just shipped them out. I have decided to dump the cheap 5 axis breakout board, ordered a better quality unit. For a start the machine will run off the pc with printer port and Mach3...but i plan to buy a more modern control system, i guess i need to make sure the machine performs well mechanically before i spend real money on the controls
  9. #297
    Mar 2018
    Good job!
    your electronics skills are million times better than mine, do you have an idea of the final price of that box all hook up? Keep up
  10. #298
    Jun 2017
    Quote Originally Posted by HuguesP View Post
    Good job!
    Thank you....sorry i did not keep track of what i spent, a few items i had lying around for a while
  11. #299
    Jun 2017
    Between home renovating and work the build is slow atm. I did manage to start milling another section of the z-axis. Also made a mounting acrylic bracket for the new bob, hope to receive it soon...
    CNC router build-plate5-jpgCNC router build-panel41-jpg
    Attached Thumbnails Attached Thumbnails CNC router build-plate5-jpg   CNC router build-panel41-jpg
  12. #300
    Jun 2017
    Just received the new bob, quickly connected and set it up. Happy to report it passed the "worst case" noise test.
    Time now to tidy up all the wiring
CNC router build
CNC router build
